Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Potentiometer with no resistance readings.
Old 5th December 2017, 10:52 AM   #1
Michael 5of9 is offline Michael 5of9  United Kingdom
Michael 5of9's Avatar
Question Potentiometer with no resistance readings.
We have a similar potentiometer to the one pictured here which gives no resistance readings between any of the three legs; is there any way of obtaining reference readings without altering the adjustment?
My thoughts were to give it a good spray with solvent switch-cleaner with the meter still connected and on
Kind Regards Michael
Heating & Electrical Engineer
Old 5th December 2017, 11:03 AM   #2
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
If you are getting no reading at all either there is something wrong with your meter or the way you are using it. What reading do you get shorting test leads? Check range setting
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 5th December 2017, 11:18 AM   #3
Enzo is offline Enzo  United States
Or whatever it is connected to is shorted.
Old 5th December 2017, 11:21 AM   #4
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
No reading at all does that mean it is zero or it is infinite?
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 5th December 2017, 11:25 AM   #5
Andrew engineer is offline Andrew engineer  United Kingdom
Very brief reply now, more later. Glad messages are working. Cut track means pot acts only as a variable resistor (like any other resistor ie 2 connections) but can be adjusted from 0 to specified maximum. 3rd leg irrelevant.
When you say 'no resistance reading', what does the ohm meter say? 0 (or say 0.3) means short circuit, eg copper track or solder bridge. anything above say 10M means open circuit, same as connected to nothing. A pot in circuit is almost bound to have a measurable resistance between each pair of legs (except for the 3rd leg of a cut track pot, which might be connected to anything or nothing.
Potentiometer with no resistance readings.Hide this!Advertise here!
TDA8932 Aux port connection and potentiometer resistance values? Xappys Class D 1 24th October 2017 05:39 PM
Audio Taper Potentiometer Resistance Coding teleman Parts 5 15th September 2017 07:23 AM
tube baxandall tone control potentiometer resistance value cl1238 Tubes / Valves 7 21st March 2016 02:47 PM
Potentiometer Resistance ??? markmay Analog Line Level 0 6th November 2010 05:31 PM
DIY Readings... Remedial Instruments and Amps 6 30th June 2004 01:00 AM
