| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
hi, would anyone happen to know any on semi. equals, or upgrades to these devices. i don't quite trust myself trying to interpret the specs safely enough to match outputs and drivers together. thanks for any help, crippledchicken
#2 |
The 5200 and 1943's can be safely subbed to ON's MJW3281A and MJW1302A.
These are 230vCE 200 watts devices. |
#3 |
hi K-amps, thanks for the response. my main ps. caps are rated at 71v. so i guess the mjl3281/mjl1302 should work no problem. would the mjl4281a/mjl4302a work, and be an upgrade? or would the drivers i have now 2sd2061/2sb1369 maybe not have enough drive. i realize alot may be circuit dependent. thanks alot, crippledchicken
#4 |
The MJL4302's have better gain and Ft but they are pricey. I don't know who stocks them.
Also at your Vce levels, the SOAR of the 1302/3281 may be as good or better... you need to verify this with the datasheets. |
#5 |
www.arrow.com has them - at $5.85 and $6.05 each. they list the 1302/1309 at $2.39 and $2.34 respectively. That's a big price delta for a small potential performance increase.
| 2sc5200/2sa1943 | stth15r06 | Solid State | 4 | 15th March 2011 10:17 AM |
| 2SC5200 / 2SA1943 Looking | funky2x | Solid State | 11 | 15th March 2011 10:14 AM |
| Is it an advantage to use this one instead of 2SC5200 or 2SA1943? | destroyer X | Solid State | 8 | 11th December 2009 04:57 PM |
| PCL 82 Hybrid 2SC5200/2SA1943 | npr | Tubes / Valves | 1 | 4th October 2007 05:46 PM |
| F/S - MJW - MJL -2SA1943-2Sc5200 SEMIS | Apex Jr | Vendor's Bazaar | 1 | 19th June 2006 11:43 PM |
| Page generated in 0.09208 seconds (76.84% PHP - 23.16% MySQL) with 10 queries |
