Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 2nd April 2004, 03:00 PM   #1
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Question 'Blanket' replacing ceramic caps with silver mica, sensible?
Hi everyone,
I searched, of course, but found slightly contradictory ideas regarding the different types of low-value capacitors.
Anyway, I've been upgrading parts in my cd player for a while (Marantz CD63ki), and have just bought 50 300pf silver mica caps through Ebay, at a fairly good price.
I am thinking of using these to replace all existing ceramic caps in my player, most of which are in digital areas I think.
Is this a safe thing to do sonically, or are there any circuits/uses where this substitution might actually degrade performance?
If noone replies I will do it anyway, and report my listening observations, but I might do other things too, I usually make several changes at once.
Thanks!
Old 3rd April 2004, 01:50 AM   #2
BrianL is offline BrianL  United States
Probably not a really smart idea, especially for bypassing
digital power supplies. 300pF is not large enough value
for digital bypassing.
This is not to say you shouldn't/couldn't improve performance
by redoing the digital bypassing. But 300pF micas
aint the way.
bel
Old 3rd April 2004, 03:43 AM   #3
sam9 is offline sam9  United States
sam9's Avatar
For bypassing, i.e. establishing a low impedance HF path from power rail to ground I've generally thought that ceramic (usually .001uF to .1uF) is the best choice do the very high bandwidth. A silver mica of similar value is huge in comparrison and expensive as well. Even if SM's were available and practical it wouls seem like a waste to me. A good place for silver micas is where you need a very low value (<1000pF) wideband cap in the signal path or feedback path.
To me bypassing calls more for a blunt instrument than a rapier.
Old 3rd April 2004, 03:56 AM   #4
Hello,
I have use silver mica's in the feedback loop of the op-amps and around the op-amps in my CD63 with good success.
I also have had good success by using polystyrene caps in the same places.
Trial and error is everything.
KevinLee
Old 3rd April 2004, 10:59 AM   #5
SimontY's Avatar
Thanks for the replies everyone!
I won't do it then, save them for something else instead.
Perhaps I will buy better ceramics and use those at some point.
KevinLee,
What positions are these please, can you remember?
Old 3rd April 2004, 11:19 AM   #6
diyAudio Retiree
" Blanket' replacing ceramic caps with silver mica, sensible?"
Either sounds like would be heavy, uncomfortable, and not very warm. Have you considered wool? It's been done to death I know, but it gives the sheep something to do. Whoops! ....... I reread your post and see that I have perhaps missed your intentions.
Old 3rd April 2004, 02:56 PM   #7
sam9's Avatar
If you are looking for improvement by replacing caps, I would suggest you start by trying to figure out where the output cap is. Increasing the value (unless it is already ok) has the potential to lower noise and extending the base response.
As an aside, I recall a 70's era reciever that claimed as a feature that it had an "integral rumble filter". What this meant was that they had stuck an itty-bitty 2uF cap in in the input. Each of the inputs, not just the phono. Now there's creative marketing. Making a "feature" out of a cost saving.
Old 4th April 2004, 01:25 PM   #8
SimontY's Avatar
Thanks, but I've taken the output caps out already, this was one of the biggest upgrades I've done to it. Removed a whole layer of sludge from the sound.
I've also changed many PSU caps, resistors, some diodes, the output op-amps, added shielding, reclocked, built supply for the clock, added damping, changed feet, etc. So I am down to a few little things now I think, hehe.
Old 4th April 2004, 06:55 PM   #9
Hello SimontY,
Here are the locations in my CD63 where I installed silver mica caps:
-CD21, CD22, CD23, CD24
-C602, C602, C603, C604
-C605, C606
-C607, C608
I am going to assume you removed QN05, QN06, QN07 and QN07, If you have not you should. Removing these muting transistors is a great mod in the CD63/67 players.
Also try installing a .01uf ceramic from input (pin 2) to ground (pin 16) on the (3) TCA0372 chips.
Good luck
KevinLee
Old 4th April 2004, 07:29 PM   #10
SimontY's Avatar
Thanks Kev, I'll look at doing those replacements. I did remove the muting transistors, altho I can't remember it making a very big difference to the sound.
I will try some caps on the chips too, great!
silver mica caps doktor Parts 14 26th April 2006 02:08 AM
silver mica and pp caps ronardi Parts 3 24th March 2005 03:06 PM
Replacing ceramic disc caps with silver mica caps? G Solid State 5 18th November 2002 02:02 PM
Page generated in 0.11573 seconds (76.60% PHP - 23.40% MySQL) with 11 queries
