Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
How do I find a Replacement Rotary Encoder?
Old 7th November 2017, 12:51 AM   #1
TankAudio is offline TankAudio  United States
Default How do I find a Replacement Rotary Encoder?
Where can I learn about rotary encoders? There are plenty of Youtube videos on "how an encoder works", but I only need to know how to replace them when they are broken. I receive a lot of rack mount gear and integrated-DSP instrument amplifiers.
When I scroll through the Mouser website, I would like to know how to describe an encoder that has:
(2) separate binary tracks, the inside track having (40) conductive marks, and the outside track having (32) conductive tracks. There are (2) sets of brushes attached to the shaft.
Thanks.
Old 7th November 2017, 03:53 AM   #2
Enzo is offline Enzo  United States
I have never had to look for number of marks.
Your encoder is either an absolute position encoder, or a relative encode. The first works like a pot in that the direction you aim it determines the output. The relative encoder is used to turn something up and down incrementally, but the position it aims tells us nothing. The common data wheel is an example of the latter - it rotates 360 degrees forever.
A three leg encoder is usually two in quadrature. There will be two on/off outputs and a common, and they operate a bit off sync. SO if you turn the shaft, one closes first before the other. Depending on which direction you turn, the circuit sees on or the other first, and so determines direction.
Given more legs, you can find encoders with binary output or Gray Code, or other.
To replace one, first, find ones that look similar. If you need a 9mm encoder, a 16mm won't fit. Does it have a shaft you can use? I find Mouser describes them well enough. They come in various numbers of steps. In the case of a data wheel, it may not matter how many steps, one would just step more spaces for a given rotation. All these factors help you narrow down to a useful selection.
Old 8th November 2017, 12:21 PM   #3
Thanks Enzo!
Old 8th November 2017, 01:49 PM   #4
bfg4wd is offline bfg4wd  United States
Default Encoder
Are you sure itís an encoder? You say it has two sets of brushes, if you mean carbon brushes like a DC motor, then chances are thatís a tachometer used for speed feedback. Encoders are used for speed but more so for position.
Ted
Old 9th November 2017, 03:50 AM   #5
Encoders have a ton of uses. In our gear, we often see them on control panels to increment some parameter up and down. A data wheel as an example. A lot of digital guitar amps, and modelers use encoders instead of pots on the panel.
How do I find a Replacement Rotary Encoder?Hide this!Advertise here!
How to use the Rotary Encoder to control the cs3310 ? cac liu Digital Source 12 25th April 2013 10:59 AM
Sure Rotary Encoder implementation Mark2727 Class D 7 6th March 2013 01:22 AM
Rotary encoder instead of buttons robmil Parts 11 16th April 2008 05:30 PM
Rotary Encoder. Need help very much! vytas Digital Source 11 23rd November 2005 12:47 PM
Digital rotary encoder rho Parts 17 3rd December 2003 03:39 PM
