Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Ideal I/V resistor ?
Closed Thread
Old 5th November 2017, 02:56 PM   #21
sumotan is online now sumotan  Indonesia
Well from my tweaking experience it’s just not the I/V resistor alone & I duly agree with what Abrax said so for me its the combination of the I/V & filter parts after that makes or breaks sound.
Cheers
Old 5th November 2017, 03:05 PM   #22
miro1360 is offline miro1360  Europe
yes, also from my experience most important is I/V concept ... there are people, which create one concept based on thick resistors, and than different concept based on foil resistors and claim, that foil sounds better, because of better TC
Old 5th November 2017, 03:19 PM   #23
Well having a piece of Kobe steak does not warant a great taste when served if ingredients & cooking is not done right.
Old 5th November 2017, 06:52 PM   #24
Audio1Man is offline Audio1Man  United States
Duke Aguiar Design Services
Hi Monte: Your comment “This effect is purely at low frequencies, practically around 50 to 200Hz as a rough guess” Is really more like DC and up.
When developing the ATS2 is where we went almost all SMD in analog. I had a problem with the DAC output signal. The current to voltage stage measured great @ 1 kHz. When I ran a THD sweep from 10Hz and up the THD% was bad. I thought that it was oscillating until I put my finger on the feedback resistor and the THD went down. The resistor 1206 was running about 50mw and it was a 25ppm part. Keep the power low and use the best parts. Duke
Old 5th November 2017, 07:44 PM   #25
Soundhappy is offline Soundhappy  France
Soundhappy's Avatar
Wire wound resistor has a low noise level that important parameter in audio.
You can try experimenting with non inductive Ayrton Perry versions: Mills MRA05 or Ohmite.
Mixing wire wound with thin films in circuit is one interesting option.
Vishay bulk foil is OK, but not always ideal.
Make point-to-point prototype is successful way to do, non body have your ears sensibility
and a particular audio system. Have a nice day
File Type: jpg 34021FD2-27C7-4CC0-BDFD-3B32F09144A7.JPG (92.0 KB, 96 views)
File Type: jpg FC6FD10F-1254-44E5-B6B7-9A41D4B5F131.JPG (75.5 KB, 97 views)
File Type: jpg 7D2615E1-DB8A-4D90-8361-968729A3C27D.jpg (365.3 KB, 96 views)
class A amplifiers with full range speakers
sings like angels in heaven
Old 6th November 2017, 06:31 PM   #26
Henderson is offline Henderson
Banned
Thanks Soundhappy,
Caddock seen on the picture as Allen Bradley....
Old 6th November 2017, 07:27 PM   #27
Soundhappy's Avatar
Hello Henderson
I read many articles about resistors and great one of Ed Simmons as well.
Low noise is desirable in audio applications.
Please try different technology resistors by Yourself so after you get more builder intuition what sound goood
Think wire wound is frequently under estimated and people don't experiment.
For minimalist circuits they are fantastic. I like it Mills.
On the right photo of my class A amplifier point-to-point prototype with different resistors under test.
Have a nice day
File Type: jpg 15DA539A-EF5A-4E1F-BF6E-74389F167264.jpg (458.0 KB, 73 views)
File Type: jpg 61F58B64-D6DD-40BC-8FEE-459F9567493C.jpg (378.6 KB, 73 views)
Closed Thread
Ideal I/V resistor ?Hide this!Advertise here!
Resistor placement of L-pad and single resistor presscot Multi-Way 3 7th December 2015 09:31 AM
The ideal dimension tijan64 Multi-Way 18 19th March 2013 02:21 AM
Ideal feedback resistor values hags Solid State 25 18th September 2007 12:54 PM
How much less from the ideal??? Leolabs Solid State 0 18th May 2007 02:54 AM
screen-plate resistor and grid leak resistor metebalci Tubes / Valves 4 26th February 2004 03:18 AM
