Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Two-stranded litz wire dielectric strength
Old 2nd November 2017, 12:52 AM   #1
50AE is offline 50AE  Bulgaria
Default Two-stranded litz wire dielectric strength
I got some two-stranded litz wire for cheap. My plan was to easy wind a bifiliar interstage transformer, as the wire is just ready to use.
My worry is finding out how much voltage potential the wire might withstand.
The spool is labeled with a efficient wire diameter of 0.224mm
The thickness of the wire I measured is 0.25mm with a micrometer. That results in an enamel coating thickness of 13 microns.
What could be the worst quality enamel used, let's assume it is to stay on the safe side? What could be its dielectric breakdown voltage?
My intention is to use the built transformer in a DC voltage potential of 350V between the secondary and primary max.
Old 2nd November 2017, 06:44 AM   #2
trobbins is offline trobbins  Australia
trobbins's Avatar
I'd doubt you would get a datasheet rating of insulation voltage rating for enamelled wire. The detailed one I have from litone doesn't go anywhere near that type of spec. Safety standards wouldn't either. I think you'd be looking for ad hoc failure with any such wound transformer. Perhaps trade one strand for an insulated wire with 'basic insulation' rating.
Old 2nd November 2017, 08:40 AM   #3
Elvee is offline Elvee  Belgium
Elvee's Avatar
According to the CEI standard 317.1, a wire of 0.224mmm has to withstand 300V AC for a grade I insulation (normal insulation) and 750V AC for grade II (reinforced enamel).
The outer diameter for grade I is 0.256mm and 0.276mm for grade II, yours is thus grade I.
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 2nd November 2017, 08:50 AM   #4
Thank you Elvee. I'd like to add a further question if you don't mind. Is this voltage rating applied to wire-next to-bare metal conditions or wire-next to-wire conditions?
Old 2nd November 2017, 09:38 AM   #5
R.I.P.
Litz wire is many strands of ultra thin wires wound in a format that brings the innermost wires out towards the outer of the bundle.
All the wires in the bundle swap repeatedly from outer to centre of core.
Typically the Litz wires <<0.1mm diameter.
Two wires each of 0.22mm diameter can't be Litz.
Maybe you just have two enamelled copper wires.
regards Andrew T.
Old 2nd November 2017, 09:43 AM   #6
The two wires are held together using the same kind of silk insulation strands that other litz wire are held too with, this is why I assumed so. I guess you're right. It's just an enameled twisted pair.
Old 2nd November 2017, 02:48 PM   #7
Elvee's Avatar
It is for the wire wound on a bare metal mandrel 12mm in diameter, but this doesn't mean the wire-to-wire rating is 2 x 300V: first, the breakdown voltage does not increase linearly with insulation thickness, and second, the spec takes the defects into account: enamel has a number of defects/100m, and this figure is low enough to ensure that in a winding, the probability of having two defects in contact from adjacent turns is negligible, but there will be spots where only one layer of enamel takes all of the insulation task, meaning it is prudent to base your calculations on 300V.... but you are free to do whatever you think safe
Old 2nd November 2017, 02:56 PM   #8
Thank you. Well, safety is really important here. You mentioned 300V AC, while my maximum potential difference will be 350VDC. I suspect it should be okay, no?
Old 2nd November 2017, 05:58 PM   #9
Elvee's Avatar
In principle, yes, since 300VAC is about 450V^, and DC puts less stress on insulating materials
Old 2nd November 2017, 07:22 PM   #10
cliffforrest is offline cliffforrest  United Kingdom
Your OP says ...."DC voltage potential of 350V between the secondary and primary max"
If you separate primary from secondary with an appropriate layer of insulating tape or paper, that will take care of your requirement, surely?
Two-stranded litz wire dielectric strengthHide this!Advertise here!
High strength Dielectric Coatings, fact or fiction dochungwell Planars & Exotics 115 9th February 2014 02:03 AM
Litz Wire for audio applications (18AWG, New England Wire Type 2) Chook81 Vendor's Bazaar 2 24th January 2012 08:32 PM
Dielectric strength M Gregg Everything Else 10 31st July 2011 11:24 AM
litz inductor wire for speaker wire. fazman Everything Else 126 20th June 2011 02:48 PM
