Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Two-stranded litz wire dielectric strength
Old 2nd November 2017, 08:52 PM   #11
trobbins is offline trobbins  Australia
trobbins's Avatar
Originally Posted by 50AE View Post
Well, safety is really important here.
Perhaps you need to think about vacuum impreg, as a method to improve creepage/clearance between existing and future pin-holes or insulation thickness variations or cracks due to winding, and use insulation resistance measurement at 500VDC as a measure of merit (as built and periodically over time).
Old 2nd November 2017, 09:45 PM   #12
pieter t is offline pieter t  Netherlands
I got some two-stranded litz wire for cheap. My plan was to easy wind a bifiliar interstage transformer, as the wire is just ready to use.
The only advantage with this wire is what you say "to easy wind...." as you can continue the complete wind without interruption.
Disadvantage is, apart from the higher risk of failure, that a wire like this will take more winding space. It takes the width and heigth of two wires, and there is the additional insulation to make it "one" wire.
When you build up the coil the normal way, that is "one layer primary - thin sheet insulation - one layer secondary", and you repeat this process until you reach the needed number of primary/secondary turns, you will have an IT with the same quality without the disadvantages of the bifilar wound (breakdown risk; winding space).
But it takes more time
Old 2nd November 2017, 10:51 PM   #13
50AE is offline 50AE  Bulgaria
An useful advice. I'm wondering if paraffin would work, or I definitely have to use a varnish compound?
Exactly! I'm trying the easy route! Layer by layer horizontal + vertical sectioning is going to last a lifetime.
Old 7th November 2017, 12:20 PM   #14
50 turns of this wire, roughly wound on a mandrel with sharp edges successfully resisted 1kV DC using a megaohmmeter So I suppose 350Vdc will not be an issue.
Old 7th November 2017, 02:03 PM   #15
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Cool
I was chiming in to suggest something like that: just wind the d*mn transformer and apply 2X at least, 3X preferred from primary to secondary.
If no sparks/atomic mushroom cloud then itīs safe to use.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Two-stranded litz wire dielectric strengthHide this!Advertise here!
High strength Dielectric Coatings, fact or fiction dochungwell Planars & Exotics 115 9th February 2014 02:03 AM
Litz Wire for audio applications (18AWG, New England Wire Type 2) Chook81 Vendor's Bazaar 2 24th January 2012 08:32 PM
Dielectric strength M Gregg Everything Else 10 31st July 2011 11:24 AM
litz inductor wire for speaker wire. fazman Everything Else 126 20th June 2011 02:48 PM
