Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 31st March 2004, 10:46 PM   #1
Default Converting my Alesis M-EQ230 to 12 volt
Do I just need to exchange the power supply in my Alesis EQ with a 12 volt one to get this to work in my car, or is there more to it? Where can I get one of these power supplies that will work? I am currently using a normal power inverter to do the job, but I would prefer the conversion to 12 volt for a number of reasons, one being that I might finish the installation and have the inverter malfunction after it is hidden in the installation, causing multiple ulcers. Any suggestions?
Old 3rd April 2004, 04:06 PM   #2
<bump>
Old 3rd April 2004, 04:58 PM   #3
Bill Fitzpatrick's Avatar
The power supply in the Alesis probably provides +/-12v or +/-15v to it's circuits.
You should latch onto a schematic to start with.
If you could find a 12 to +/-12v converter you would probably be in good shape assuming you have the knowledge to make the chaneover.
The easiest route is to use the inverter. If it's well made product it shouldn't be any more prone to failure than any other component.
Alesis Matica 900 Audio Tech Solid State 6 8th March 2009 09:05 AM
Alesis RA 150 - Good or Bad?? Brit01 Solid State 5 24th July 2008 10:52 AM
Switching 230 Volt Transformer to 120 Volt OMNIFEX Parts 10 6th April 2008 04:34 PM
Alesis LCD goodlife Parts 1 24th September 2005 07:24 AM
any one know if the Alesis RA 300 amp can be mod ? zuka Solid State 2 14th April 2003 05:58 AM
Page generated in 0.07372 seconds (73.48% PHP - 26.52% MySQL) with 10 queries
