| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I am trying to locate a set of plans for a pair of HT mains that would work nicely with the Vifa PL22 8" woofers I have.
I have looked around quite a bit and the best I can come up with is to use a variation of the Kit 281 enclosure since the PL22 specs appear to my inexperienced eyes to be very close to the AV8: AV8 PL22-04 Fs 35.8 27 Vas 56 56 Qts 0.39 0.34 Qes 0.43 0.37 Qms 5.65 5.91 Xmax 5.6 mm 4mm EBP 83.3 SPL 89.3 dB 86db BL 9.06 N/A 10.9 Le 1.15 mH 2.7mH Re 5.48 ohms 3.2 The inportant differences is that the vifa goes a little lower, and it's 4 ohm vs 8 ohm and the AV8 has a somewhat flatter response, especially between 1-2khz. I am thinking of using two of these drivers in a smaller version of the 281 sealed enclosure: about 23l vs. 27 from the 281 plans. This gives me a F3 of about 60Hz which seems fine for HT use. I also like the simplicity of a sealed design because there are fewer variables to get wrong. Does this seem reasonable? Am I missing something here? Any suggestions for tweeters that will integrate well with minimal fussing with the crossover. I would also greatly appreciate a helping hand with the crossover design, especially how one handles two 4 ohm woofers.... Thanks in advance Philip |
#2 |
two 4 ohm drivers in parallel will cripple your amplifier,
#3 |
I've also checked out the PL22-04.
Sensisitivity is low for a 4 ohm unit, but linear throw is good. Its a pure bass unit, entirely unsuitable for midrange use. They would be excellent for the subwoofer, or 5 small sealed box AV speakers with left and right with stereo subwoofers. Used in series they would also be in the right ballpark for some 3-way louspeaker designs, instead of a 8 ohm 10" or 12" unit. |
#4 |
Hi Philip, I would suggest just waiting on the AV8s. There's no way you could drop in PL22s.
BTW, where do you live? I'm in Gaithersburg and I own Kit281s. |
| F1 Voltage sanity check | rpafenberg | Pass Labs | 7 | 28th March 2009 10:42 AM |
| Sanity Check ..... please | Lostcause | Digital Source | 0 | 16th October 2008 06:19 PM |
| This model can't be right... need sanity check | NogginBoink | Subwoofers | 4 | 30th July 2005 09:14 PM |
| Ideas for system using vifa Pl22s, please? | philiprst | Multi-Way | 0 | 2nd April 2004 01:52 AM |
| Sanity check | planet10 | Multi-Way | 14 | 7th March 2004 10:15 PM |
| Page generated in 0.08163 seconds (86.74% PHP - 13.26% MySQL) with 10 queries |
