Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 12th October 2017, 04:07 PM   #11
catd is offline catd  Europe
catd's Avatar
Thanks for the advices.
First, I would test some single different OPs until I decide which type I choose for all.
The power consumption will not be a problem. The power supply is a 30VA transformer and standard +/- 15V voltage regulator (7815/7915). I could change the power supply in case of emergency, it is a separate component.
As far as I know, some (FET-) OP-types do not like, if (neg.-) input and output are connected directly. I would have to consider this in the selection, because preferably I want to make no further changes to the circuit or the PCB. But TL072 does not seem to belong to those.
Perhaps first not an adapter board, but a diy-adapter-socket would be better. Bottom side to fit in the 747-sockets at the equalizer board, top with DIL-8 socket to test various up-to-date ICs.
Old 12th October 2017, 06:26 PM   #12
Mooly's Avatar
The circuit diagram you posted is all classic 'text book' circuitry. The TL072 should be an ideal swap I would have thought.
Jfet opamps have a peculiar 'problem' of phase inversion if the common mode input voltage range is exceeded... that will never happen with your circuit.
Old 12th October 2017, 07:33 PM   #13
catd's Avatar
"all classic "textbook"circuits" That I had also thought.
When I buy parts the next time, I will order some of the suggested IC types and test them.
Port equivalent janus44 Multi-Way 5 11th September 2016 12:17 PM
2sk373 or equivalent bvtrinh Parts 5 23rd November 2015 03:29 PM
UF1620CT equivalent Darkinnersoul Class D 4 6th September 2012 02:48 PM
T/S to Equivalent Circuit? dhalbakken Multi-Way 2 21st June 2012 12:44 AM
6BM8 Equivalent GlidingDutchman Tubes / Valves 11 15th April 2009 07:40 PM
Copyright ©1999-2017 diyAudio
