| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Does anyone here use or can recommend a good PC oscilloscope, USB connection.
Preferably with software that can do spectrum analysis or dual trace and not so expensive? Thanks |
#2 |
http://www.parallax.com/detail.asp?product_id=2811
Never used it but have used other parts from them and they seem to be a good company. OPTAscope Technical Specifications: 2 Channels 1 Ms/s Maximum Sample Rate with One Channel 500 Ks/s Sample Rate with Two Channels 20 Vpp Maximum Input for Channel 1 and Channel 2 200 kHz Bandwidth 8-Bit Vertical Resolution 1 M Ohm Input Impedance Trigger on Rising or Falling Edge at any Voltage Variable Trigger voltage on Channels 1 and 2 Horizontal Trigger Position Settings at 10%, 50%, and 90% Auto and Normal Trigger Modes 3 probes USB 1.1 Support (no additional power supply required!) Size: 5 x 2.25 x 1.5 (in.); 12.7 x 5.7 x 3.8 (cm) Weight: 8 oz; 227 gm |
#3 |
Is the link right? I can't get it to display. "not found in inventory"
#4 |
Just need a 9 on the end of that link.
http://www.parallax.com/detail.asp?product_id=28119 looks pretty cool, except the 20vpp input, I wonder if you can use standard 10x probes to get more voltage? 200Khz bandwidth isn't that great tho. You'd be better off with a used Tek for the same price, with 50Mhz or 100Mhz bandwith. |
#5 |
Yeah, I wondered if it would work for an audio application, this oscilliscope is manufactured for troubleshooting low voltage electronics. I think they are in stock after mid-april.
#6 |
$189... and no spectrum analyzer... for that price I agree a used Oscilloscope on ebay will be better. Thanks for the suggestion though.
I've seen the pico USB product, but will cost me $500 to $800... but it includes the spectrum analyzer. I need the S.A. 'cause I'll be using this for testing audio projects, gear, etc... |
#7 |
I looked in to the Pico once. At that time if you do some web surfing there were a couple of sources that knocked off between US100-200. At least for the 16-bit version.
#8 |
What do you guys think about this one? Also USB, with spectrum analyzer, but cheaper than the Pico... I also like that it's a tabletop model.
http://www.bitscope.net/store/?p=view&i=item+2 |
#9 |
You probably need 16 bit for audio spectrum analysis.
Dave |
#10 |
If you are looking at THD, 16 bits lets you measure down to ~.001%-.002% while 8 or 12 bits is more limiting. If you are a low THD+N fanatic you long for a 24 bit scope!
| oscilloscope kit | henryr | Equipment & Tools | 5 | 18th June 2009 11:08 PM |
| Need help with oscilloscope | error0 | Equipment & Tools | 2 | 6th April 2008 02:22 AM |
| Oscilloscope | XTAL | Parts | 0 | 18th March 2005 06:05 AM |
| How to use an oscilloscope | SimontY | Equipment & Tools | 15 | 16th September 2003 11:46 AM |
| oscilloscope | Kilowatt | Digital Source | 12 | 22nd January 2002 01:30 AM |
| Page generated in 0.09958 seconds (78.29% PHP - 21.71% MySQL) with 10 queries |
