Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 31st March 2004, 05:16 AM   #1
sam9 is offline sam9  United States
sam9's Avatar
Default Pot with added feature. What & why ???
I've got a 100k dual pot which is otherwise an ordinary cheap pot. It has something I've not seen before - a fourth solder terminal. While the resistance between the wiper and either of the standard terminals varies 0-ohms to 100k-ohms, the resistance between the wiper and this extra terminal varies from 10k-100k. This must have some purported benefit but it beats me.
Anyone know why this is here and what it is good for?
Old 31st March 2004, 06:15 AM   #2
Steve Eddy's Avatar
Default Re: Pot with added feature. What & why ???
It's a loudness tap which allows for a reduction in volume without having to change the position of the pot.
se
Old 31st March 2004, 07:16 AM   #3
I'd suggest it has something to do with loudness buttons.
They are not for changing volume, they boost bass at low
volume settings and have less effect as volume is increased.
sreten.
Old 31st March 2004, 02:23 PM   #4
sam9's Avatar
Sounds plausible. I think it is a feature I can do without although I'm a little uncertain how it would work - some kind og filter parralllel to the wiper-end stop i suppose.
Old 31st March 2004, 03:00 PM   #5
Those are indeed used for the loudness function. These were quite fashionable in earlier days. It is wired in a way (using caps and resistors) that low and high frequencies are boosted with low loudness settings -- in order to "compensate" for Fletcher-Munson.
Charles
Old 31st March 2004, 03:11 PM   #6
markp is offline markp  United States
Usually it is a 40% tap. Like others said for loudness compensation.
If it sounds good... it is good!
Old 31st March 2004, 03:34 PM   #7
owel is offline owel  United States
I feel old. Yes, it's a tap for the loudness circuitry. I like them... the bass boost circuitry is only effective at low volumes.
Old 31st March 2004, 05:55 PM   #8
sam9's Avatar
Can anyone post a schematic as an example?
Old 31st March 2004, 06:01 PM   #9
Steve Eddy's Avatar
Hmmm. I guess it is for a loudness circuit of a sort, one which only gives an apparent bass boost at lower volumes. Since we lose sensitivity at lower volumes in both the lowest the highest frequency ranges, I couldn't see how such a tap could be used to implement both a bass and treble boost.
I did some poking around and the loudness circuit is implemented as a simple RC network to ground off the tap.
Learn sumfin' new every day.
se
Old 31st March 2004, 06:03 PM   #10
Steve Eddy's Avatar
From http://members.home.nl/kvdijke/Philips/B5X72A.html
se
feature request ...... sakis Solid State 3 14th July 2008 01:07 PM
Quick Reply feature? Glowbug The Lounge 8 7th March 2008 06:05 AM
ADD Login Feature To Pages?? bear Forum Problems 2 21st November 2004 08:36 PM
Page generated in 0.09371 seconds (80.49% PHP - 19.51% MySQL) with 10 queries
