If someone has recently bought capacitors ALS30 with the dimensions 77mm x105mm, can they tell me how much they weigh them?
In the datasheet it writes about 690 grams but the ones I bought (ALS30A683NF063 ( 68000uF / 63volts) are much lighter ... Why?
Thank you .
Best regards,
Vitali
Thank you .
Best regards,
Vitali
If purchased from a known supplier, Mouser, RS Components, Farnell etc, think nothing of it. If substantially lighter and through fleabay, send them back for a refund.
I bought 10 pieces from Mouser and it's very weird that we only weigh 400 gr instead of 690 grams ... Do you think I should worry? A lot of money
- Design & Build
- Parts
- A question about BHC ALS30 capacitors
