Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Mount Brackets with internal Threads wanted
Old 10th August 2017, 01:39 PM   #1
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Default Mount Brackets with internal Threads wanted
I am looking for such parts like that one under
T brackets (12p) - MakerBeam
(for datasheet go to
http://download.tinkerforge.com/make..._t_bracket.pdf),
but with internal thread instead normal hole as to see under this pics:
Pololu Universal Aluminum Mounting Hub for 4mm Shaft, #4-40 Holes (2-Pack)
http://img.dxcdn.com/productimages/sku_220085_2.jpg
http://www.marshallmonitors.com/prod...V-VP-TBRKT.png
For making a service without completely dismanteling I open the bottom of the enclosure with a jigsaw - go to post #6 under
GRAAF GAAFiti WFB ONE - Schematic needed
For subsequent assembly of the cut out part I look for this T brackets with internal thread.
Thank you very much for your advices.
Old 12th August 2017, 08:42 PM   #2
Without the right keyword it is impossible, to find the right parts on the web.
The appropriate keyword for the wanted part is
"Tapped Strip" (in German "Gewindestreifen" or "Gewindestange")
and not
"Mount Bracket with internal Threads" or "Thread Rail"
https://www.elma.com/en/products/enc...strips-detail/
BGT 384-2: Gewindestreifen bei reichelt elektronik
https://www.southco.com/static/Literature/t2.de.pdf
| Gewindestange, Untergeordnetes Baugruppentragersystem KM6-II |
| KM6II Gewindestreifen 84TE |
http://docs-europe.electrocomponents...6b815854cc.pdf
https://www.schneidersladen.de/de/ge...ifen-84te.html
https://www.isel.com/de/gleitmutter-2-x-m6.html
Mount Brackets with internal Threads wantedHide this!Advertise here!
WTB: Rack mount brackets Stevens in SC Swap Meet 1 7th August 2015 08:40 PM
Technics SL1200 internal brackets, regulator and external power supply davefl Analogue Source 47 30th December 2014 11:58 PM
Wanted - Panel mount trimpots dgta Swap Meet 0 23rd September 2012 06:34 PM
Wanted internal speaker wire mgreene Swap Meet 1 9th December 2003 03:14 PM
Help : Best way to flush mount speaker drivers and other router tips wanted?? Cacophonix Multi-Way 7 23rd April 2003 07:47 PM
Copyright ©1999-2017 diyAudio
