| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I have a handfull of caps thats rated 40V. Now id like to run 60V rails, can i couple 2 of them in series and get the equalent of a 80V cap with twice the ESR ??
Cheers Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#2 |
Banned
you will get some double voltage half capacitance caps. So if you want double voltage and same capacitance you need to parallel two of the two in series caps and thus need four.
#3 |
Thanks.
Magura
#4 |
Isn't it important to parallel the series caps with resistors to properly split the load? I read that somewhere once... Otherwise the top cap sees most of the voltage and still runs the risk of operating beyond its rating.
Or something like that.javascript:smilie(' -RobRoy
'You know you've achieved perfection in design, not when you have nothing more to add, but when you have nothing more to take away.' -- Antoine de Saint Exupery |
#5 |
To couple caps in series seems to all in all being a bad idea
![]() Magura
| Capacitors in Series - phase changes? | GeorgeBoles | Pass Labs | 5 | 23rd January 2007 10:28 PM |
| capacitors in series in PSU | Wagener | Solid State | 12 | 7th May 2004 07:48 PM |
| BG F series capacitors?? | Stabist | Parts | 6 | 26th February 2004 09:43 PM |
| CDE Mini series capacitors | contaxchen | Swap Meet | 1 | 7th December 2003 06:47 AM |
| Series of capacitors | Thomas | Parts | 3 | 27th February 2002 04:52 PM |
| Page generated in 0.08352 seconds (72.35% PHP - 27.65% MySQL) with 10 queries |
