Speaker wire okay from relay to speaker terminals? - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 19th June 2017, 12:43 PM   #11
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
There´s "proximity" and "proximity"
A couple parallel wires an inch away or more can have how much parasitic capacitance coupling between them? 1pF ... 5 pF? ... same as 0
Now if you tightly *twist* them, copper to copper may close down to 1 or 2 mm, with a nice plastic dielectric between them ... mutual capacitance can become 50 times as much, and become significant.
FWIW Radio transmitter gain stages used to be "neutralized" , meaning "made stable", by feeding back some RF out of phase and in a controlled way by using "gimmick capacitors" .... 2 short pieces of wire (and I mean *short*, 1/2" or less) , twisted together more or less tightly.
So wire to wire capacitance is a very real and useful phenomenon.
Notice value and position of the gimmick capacitor Cpk:
Is a 0.1pF capacitor significant?
You bet
You sometimes see such a connection made by means of a "gimmick" capacitor merely consisting of two wires twisted together.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 19th June 2017, 01:04 PM   #12
DF96 is offline DF96  England
Interchannel crosstalk from speaker wires is more likely to come from inductive coupling.
Twisting a pair of wires is likely to raise capacitance but this should not be a problem. Given that the load is low impedance when compared to the line characteristic impedance it is line inductance which dominates - and this is minimised by keeping the wires close together.
Old 19th June 2017, 04:13 PM   #13
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Nothing is better than a good cheap superconductor. If below -270 °C, still better.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 21st June 2017, 03:55 AM   #14
I have already twisted them into separate L/R pairs as I said, and they will travel to the terminals separately without contact.
Originally Posted by DF96 View Post
I am not sure what the heatshrink is for - I would not bother. Keep some distance between the two channels; definitely do not twist them together!
They pass under a heatsink, it's hot (Class A).
Wouldn't exceed the temp-rating of the insulation though, so I can skip that if not needed or undesirable for some reason. I didn't have a temp rating for the other wire which is why I considered some secondary insulation initially.
I'll keep some distance between them as advised.
Where to buy tri/quad wire speaker terminals? insider9 Parts 14 24th May 2017 12:07 PM
output voltage at speaker terminals Shelah Solid State 30 5th July 2015 10:15 PM
Capacitors on/across Speaker Out Terminals 1965GTO Solid State 5 23rd April 2011 12:51 AM
resistor across speaker terminals mcmahon48 Multi-Way 6 23rd July 2010 05:47 PM
I’m looking for really good speaker terminals Progg70 Parts 8 4th July 2007 08:57 AM
Copyright ©1999-2017 diyAudio
