Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
audio capacitors 1800/150 uF ?
Old 24th July 2017, 10:42 PM   #321
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
"Accusations are occasionally made that objectivists can't hear, and conversely that subjectivists hear things that aren't there. This being the entertainment industry, I hope everyone is having a good time" Guess who.....
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 25th July 2017, 06:57 PM   #322
thedoc735 is offline thedoc735  United Kingdom
The supplier of the Sophia's has graciously agreed to send me the converter that they used and which showed no problems with buzzing. I will be comparing it to the one I purchased and if there is an audible difference (i.e. quieter) the AIRLINK will be going back!
Should have the replacement by friday.
Old 29th July 2017, 01:43 AM   #323
Got the sellers' converter that they say they had no problems with! ~ It is useless! ~ It's a 100v converter for a pair of 120v amps; needless to say it doesn't work properly/sounds dreadful! So it's going back at their expense. It's another AIRLINK and looks identical to mine but the spec. is different.
Be taking the amps to local Hi-Fi specialist repair centre to see if there is a problem/fault? Seems unlikely that both amps develop the same fault at the same time! So, maybe it's just an unfortunate aspect of the design/quality?
Other owner's have reported this too apparently!
Old 8th August 2017, 12:15 AM   #324
The sophia Electric 91-01 300B has been returned as it did not work correctly on the UK mains power grid.
Old 8th August 2017, 07:40 AM   #325
Originally Posted by scottjoplin View Post
This sounds remarkably like brainwashing to me, some military organisations do very similar things
I am not talking about things like "the Moonies", Scientology, Warren Jeffs (FLDS), Waco, Jones-town, etc. I am talking about people like: The Dali Lama of Tibet, Sri Ramakrishna and other great luminaries
Old 12th August 2017, 11:42 AM   #326
ADDENDUM: (to post 315 in this thread)...
...having disposed of the Sophia amps in favour of a John Wood 6L6 (UK - 230v) power amp, I can now say definitively that the CARY 100t DAC does have improved performance following the upgrade i.e. it just sounds better to me, and that's all that matters - surely?
audio capacitors 1800/150 uF ?Hide this!Advertise here!
Jupiter 2 uF 100V Capacitors Davec113 Swap Meet 0 10th September 2012 07:13 PM
FS: 2 pcs. Audio Note 0.47 uF silver capacitors mbede Swap Meet 2 8th December 2011 06:40 PM
15000 uF capacitors? rmihai Solid State 23 22nd September 2006 09:55 AM
26,000 uF 75V capacitors Possum Swap Meet 4 23rd April 2003 07:35 AM
1800 uF / 200V caps JohnR Swap Meet 0 1st February 2003 01:35 AM
Resources saved on this page: MySQL 70.00% / PHP 38.49%
Copyright ©1999-2017 diyAudio
