| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Banned
go and get yourself one. I collect a good handfull of Tek 7000 plugins now, and to give those not sitting in my 7904 a "garage" i just ordered a 7313.. at that price could not resist http://www.rainer-foertig.de/Oszillskope.htm
#2 |
Last year my Tek scope broke, well I could have fixed it. Well I did not because you can buy a nice Tek scope on EBAY for only $240. Yep, I purchased a Tek 475A, it's condition is like new.
check it www.ebay.com search for Tektronix , you can't beat a Tek scope even a old one. till, Next time get your self a Tek 7854 with the amp that has a 10uv sensitivity.
Jim W. |
#3 |
Just having a nose around at the moment.
Thus far seen a Techtronics 2465 300meg scope,reserve £260. Seems probes manual etc are extra. No doubt the price will go lots higher, the buyer says the unit is worth £1000+ Views? Setmenu |
#4 | |
Banned
In fact, what i miss most often are more probes! At Foertig they also sell 475s, but not at that good price than yours. http://www.rainer-foertig.de/Oszillskope-2.htm |
#5 |
[QUOTE]Originally posted by setmenu
[B]Just having a nose around at the moment. Thus far seen a Techtronics 2465 300meg scope,reserve £260. Seems probes manual etc are extra. No doubt the price will go lots higher, the buyer says the unit is worth £1000+----------------------------------------------------------- No, the price of a 2465B in excellent condition is around £700. Don't pay more. You do need 400MHz to look at digital waveforms properly. Don't buy the tek probe 6137; the HP 500MHz probe is better, with a smoother waveform. Lots of ringing on the 6137. Best way to look is to solder lread of correct impedamce to the circuit board. |
#6 |
Hi fmak
Even £700 is a bit steep for me at the moment, as I have no idea how much real use the unit will get. It would be a nice toy though It it clear from your comment, that a good deal of bandwidth is required to measure the signals with this digital lark.. This does seem to preclude cheap scopes! I do not even have any idea of how to measure these circuits, I presume I also need to obtain some sort of 'thingy' to supply relevant signals etc.. Arrrgh.. I know so little and it could cost quite a bit of ££££ to learn. Any other makes of scope that you can recommend? Hmmm, I seem to be moving off topic with the above... oops Setmenu |
#7 |
---------------------------------------------------------- Unfortunately, the cost of transport plus the possibility of VAT and Imnport Duty makes it inadvisable to buy from the US. Also most on ebay.com don't offer any form of guarantee. |
#8 |
Hmm ,
400mhz scopes don't come cheap [did not really expect them to..]There does not seem to be a whole lot of choice [Tektronix ] on the Uk ebay at the mo. Surely Tektronix are not the only good make out there? Setmenu |
#9 |
[did not really expect them to..]There does not seem to be a whole lot of choice [Tektronix ] on the Uk ebay at the mo. Surely Tektronix are not the only good make out there? ---------------------------------------------------------------------- Most Japanese scopes here are 100MHz or less. 200-400MHz analog scopes are rare except teks. You can try the tek 7 series system which is older and may be cheaper, but you may have problems due to age. |
#10 |
Banned
I doubt you really need the 400MHz. Also in case a scope (TEK) is labeled 200MHZ, this does not mean if you apply a signal with more MHZ you see nothing, it also is displayed with some more error. And, have a look for probes, do you really want to buy a good 400MHZ probe ? at some speed the probe becomes more expensive than a good used scope. Downsize your aim to <= 200MHZ, get a 453/465/475 scope if you like it smaller, or any fast enough 7000 mainframe, a timebase, and one of the bettet Y plugins. This is affordable, and very good quality. I doubt you will reach much better with an analog scope. At university i had to work with a digital scope, and they may be faster (but then expensive and need expensive probes) but i did not like the handling and the picture they made. Keep in mind what gear was made in the 70´s and 80´s , i suspect also later, using these scopes. You develop more advanced stuff?
Tektronix may not be the only, but you get good (best?) quality for your money. |
| Great deal on Digital scope. Is this enough scope? | hifimaker | Pass Labs | 1 | 1st May 2007 09:59 PM |
| My first scope! | bigwill | Equipment & Tools | 3 | 7th July 2006 05:10 AM |
| can your 'scope do this? | jackinnj | Equipment & Tools | 6 | 30th June 2006 02:21 PM |
| PC as a scope | Ryssen | Equipment & Tools | 3 | 2nd January 2004 09:50 AM |
| Page generated in 0.09854 seconds (87.72% PHP - 12.28% MySQL) with 10 queries |
