I'm in the process of overhauling a couple of DDrum4 modules and I am struggling to find a suitable volume pot. It's a 10K linear pot. 16mm body with a 12mm long 4mm wide flattened shaft. Panel mounted with what appears to be pins for right angle mounting bent upwards. I'm finding it very hard to locate a part that has a slim enough shaft in this format.
Does anyone have any hints or even know the part number. And does anyone know if there is a schematic floating around for these units?
Maybe you can do without the flat, and use a different knob.
1pcs WH5-1A 10K Ohm 4mm Shaft 3 Terminal Linear Taper Rotary Potentiometer | eBay
