Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 23rd March 2004, 09:17 PM   #1
red is offline red  Romania
Default Converting a DC milivoltmeter to AC
Hy I have this DC milivotmeter and I need to measure AC for determining the T/S parameters for drivers.
You may ask why not buy a multimeter?The answer is a lot cheaper to make a simple circuit than to buy a new multimeter right?
So I found a circuit that may solve my problem.This one in the pic.
In a simulation on electronics workbench the eror is about 10%.A bit much.So do you know a circuit better than this one?
Old 24th March 2004, 11:03 AM   #2
Frank Berry's Avatar
If you increase the value of the 100k feedback resistor on the #2 opamp (on the right), the gain and output voltage will come up.
Be sure to use high speed diodes.
Frank
Old 24th March 2004, 12:36 PM   #3
Well I have to be sure that erors are still prety small but I don't know.Someone showed me another schematic that might work.He told me that this is used in multimeters.Maybe so.Anyway it has some erors that are corected by the R2/R1 amplification and this being almost 1.125 this wold corect the erors.As you can see in the pic the multimeter shows exactly what the source is.The analogue Voltmeter shows a value bigger than the multimeter.The advantage is that at bigger voltages the eror drops and is actualy showing the real value.
Old 24th March 2004, 12:44 PM   #4
After playing around a bit I seem to have foud the answer (see this pic).
I only changed the R2 and made the opamp real).In a few days when I'll have the time I'll make it because seems the best choice(fewer precision resistors and only one opamp).I'll use the TL072 opamp or the TDA2330A (haven't decided yet.)Maybe you have a better ideea...
Old 7th October 2006, 04:22 PM   #5
mikee55 is offline mikee55  United Kingdom
mikee55's Avatar
Default In the same boat.
Hi Red, I need to do this too. I just bought a new meter that measures low voltages,but silly me, it reads DC not AC. How are you getting on? Do I build your circuit? Please can you tell me what to do? And what do I need? I've got to tackle the volume used up by driver yet! Are you reffering to Rod Elliotts site for measuring T/S parameters.
PLEASE PLEASE talk to me. Pretty Please!!!
If it don't work, I'll fix it in the mix! Or visit http://lsdp.proboards.com/index.cgi
Old 8th October 2006, 10:38 AM   #6
Hi Red,
your first post looked like a precision full wave rectifier.
You seem to have moved away from that. Go back.
The grounded non inverting inputs should have resistors to reduce the output offset of each opamp.
The resistor value should be equal to the parallel combination of resistors on the inverting input(s).
Could the offsets have been confusing the interpretation of the output readings?
Some very low offset opamps do not respond well to this standard technique. eg. op228
regards Andrew T.
Old 8th October 2006, 10:42 AM   #7
to measure T/S you need accurate frequency measurement and a system that works at very low frequencies.
This is needed to allow you to see or read the slowly changing signal.
Try measuring 10Hz with a 2.5 samples/second multimeter to see what I mean (analogue might be better here).
An Fs above 30Hz just about avoids the problem
regards Andrew T.
Old 8th October 2006, 11:16 AM   #8
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
What you are building is a rectifier that makes half waves from sine waves. You need to put a capacitor at the output, and then measure with a DC meter. I saw some post measuring with an AC meter, which is wrong.
The precision rectifier has very specific ratios of the resistors which can be found on the net. Tweaking the resistors for one specific case means you can only measure this one specific case.
Find the precision rectifier on the net, check the resistor ratio, put the output in a cap so that the ripple is less than a few percent at your lowest freq (10Hz?), and then put on a DC meter and tweak THAT meter to give a reading correcsponding to the RMS value of the AC input sine wave. And no, it is not accurate for other waveforms than sines.
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 8th October 2006, 11:34 AM   #9
lineup is offline lineup  Sweden
lineup's Avatar
Default ESP test instruments
Figure 4 shows the complete meter amplifier,
and uses a 2N5459 J-FET for the input.
... linear up to at least 80kHz
Audio Millivoltmeter - Rod Elliott - ESP (Original Design)
ESP Projects: Audio Test Equipment
and happy testing!
lineup
lineup
Old 8th October 2006, 08:45 PM   #10
Hy guys,
I posted that schematic long ago. I tested it but it didn't work as expected. The problems seemed to be at first wiring the opamp, then the dc offset, then the diodes...I still haven't solved the problem.
Converting TO-220 to TO-247 Clipped Car Audio 5 24th July 2007 06:59 PM
Converting a DAC harrygrey382 Digital Source 48 15th June 2007 09:16 PM
Converting a DAC-in-the-Box to I-out? Aleksunder Digital Source 0 26th May 2007 11:44 AM
Converting a DCC into a DAC harrygrey382 Digital Source 0 21st May 2007 10:10 AM
Converting Bl ht_boy Multi-Way 2 12th December 2005 04:32 AM
Page generated in 0.10269 seconds (81.71% PHP - 18.29% MySQL) with 11 queries
