Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 21st March 2004, 03:31 AM   #1
Garbz is offline Garbz  Australia
Send a message via ICQ to Garbz Send a message via MSN to Garbz
Default OP27 Replacement in KG amp?
Hi all
Some of you might have seen my message last week or the week before, i'm in the process of starting a Gilmore Class-A Dynmaic Heapdhone ampifier.
I've come across a hitch with the OP27. As far as I understand this chip feeds the output into the DC offset with a little voltage gain so the amp runs in class A??? Is that right i'm not sure, i don't normally work with discreet amps.
The problem is i'm on a really low budget, and find the OP27 and it's high retail price a bit expensive. Also i have no easy supply of opamps so i'll need to order from texas instruments, so add shipping costs and i definatly can't afford it.
Texas Instruments offers samples of most of their chips (inc Burr Brown chips), and the OP27 is not one of thoes chips.
Is there a substitute i can use instead of the OP27, which is availuable from Texas Instruments, or is cheaper, and doesn't compromise sound quality? It doesn't matter if they don't have the same pinout i can easily modify the design.
Old 21st March 2004, 04:22 AM   #2
I don't mean to sound discouraging, but most of the questions that could possibly be asked regarding this amplifier have already been asked and answered on the Headwize forum.
I know it's hard using the search function when you don't know for sure that your question's been asked, but there really is a lot of information there.
http://headwize2.powerpill.org/ubb/s...gilmore;opamp;
Old 21st March 2004, 05:28 AM   #3
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
OPA27GP
Mads K
Old 21st March 2004, 07:01 AM   #4
Electrons are yellow and more is better!
peranders's Avatar
Garbz, the opamp is used as DC-servo and virtually any good audio opamp will fit because the application isn't very critical. Just pick an opamp and I can tell you if it's good or not.
/Per-Anders (my first name) or P-A as my friends call me
Old 21st March 2004, 08:41 AM   #5
per,
i have a cdplayer with op27 as servoopams - would the opa627 perform better.....?
Old 21st March 2004, 10:13 AM   #6
sorry i did try searching op27 replacement in both forums but came up with nadda. Thanks for the links.
I've got opa134, opa627, opa637, on hand.
I can easily get TL071, LF351, LM301, LM308, lm747, ne5534n, ne5534an.
I'm gonna use the opa134 (cheap = win)
Also mad_k don't know where u find the Gp but i can only see the GB, and no samples availuable and 10usd + god knows for delivery.
Old 22nd March 2004, 12:38 AM   #7
I've built this amp. I use the OP27 in it, but others have used the OPA227. Those are the two most commonly used in the servo. The OPA132 you have will work. I say don't waste an OPA627 in there as it won't impact sound at all.
Old 22nd March 2004, 02:11 AM   #8
ok thanks a lot everyone.
Replacement LED DreadPirate Parts 11 14th November 2009 04:45 PM
Replacement amp for A-Bus? Greg911 Class D 0 16th November 2008 02:33 PM
OP27. How good is it? mudihan Chip Amps 42 12th September 2006 03:19 PM
OP amp replacement mieze245 Chip Amps 0 19th September 2004 06:46 PM
Replacement for 5R4 Ralph Tubes / Valves 8 16th December 2003 10:02 AM
Page generated in 0.09659 seconds (77.60% PHP - 22.40% MySQL) with 10 queries
