| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#11 | |
#12 | |
Silk is listed as 2.5-3.5. Some folks have been using cotton piping (typically found at fabric stores) with good results. se |
#13 | |
se |
#14 | |
There are many derivatives from PTFE. Tefzel is called ETFE and has a dielectric constant of app 2.5. Here is the datasheet: http://www.teflon.com/Teflon/downloads/pdf/h96518.pdf I am using this 26 AWG Tefzel isolated wire for interlinks with good results. But it is also silver plated copper wire and not solid silver. Cheers
#15 |
You can make the wire you like.
Take the bare wire you like, (bus wire, the speaker cable of your choice - stipped of insulation, something else you like) and then purchase the sleeving you like. I solder the first end, cut to length, slide the sleeving over the wire, solder the other end. Cutting teflon tubing is easier than stripping teflon wire. This works well for point-to-point projects. I use teflon for it's high voltage, high current, high temp properities. Teflon wire will survive a dumb mistake best. Aud_Mot |
| Winding coil with Teflon insulated wire ? | Bernhard | Parts | 1 | 1st June 2008 10:25 AM |
| why does teflon insulated wires need a very expensive wire stripper? | jarthel | Parts | 7 | 30th April 2007 02:53 AM |
| Teflon insulated magnet wire? | serengetiplains | Parts | 52 | 17th June 2004 09:55 PM |
| Good place for Teflon insulated chassis wire?? | Aerosol | Parts | 3 | 25th May 2002 07:15 AM |
