Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
best metal for heatsinks?
Old 15th March 2004, 11:35 PM   #1
sardonx is offline sardonx  Canada
Default best metal for heatsinks?
I searched but couldn't find anything. Which metal has the best heat conductivity and heat dissapation? I need to build a heatsink. Anyone know?
The End
Old 15th March 2004, 11:38 PM   #2
damonpip is offline damonpip
Send a message via AIM to damonpip
Diamond, silver, copper. I cannot find the link that proves this at the minute though.
Old 15th March 2004, 11:44 PM   #3
OliverD is offline OliverD  Germany
OliverD's Avatar
After copper, the list continues with aluminium.
Cheap, easy to work with, non-magnetic, ... There is a reason why everybody keeps using it
Old 15th March 2004, 11:48 PM   #4
Magura is offline Magura  Denmark
Magura's Avatar
A truth with modifications.
For heat conductivity, this is correct.
For dissipation, it is not correct.
An anodized black aluminium surface will have far better dissipation properties than any of the above, for the simple reason that you can dye it black. Any of the other materials you would have to paint black.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 15th March 2004, 11:50 PM   #5
that was a quick response.. thank you.
Aluminum is not a problem to get
The End
Old 15th March 2004, 11:51 PM   #6
Bill Fitzpatrick is offline Bill Fitzpatrick  United States
Bill Fitzpatrick's Avatar
Copper has better conductivity but poorer dissapation than alum.
Old 15th March 2004, 11:53 PM   #7
so ideally the chips should be mounted to a copper bar (of appropriate dimensions) and the fins made out of black anodized aluminum...?
The End
Old 16th March 2004, 12:15 AM   #8
breguetphile is offline breguetphile  United States
breguetphile's Avatar
It needs to be said that just because one material is greater than another does not mean it is appropriate for the job. The reason aluminum heatsinks are used so frequently is because they are best 99% of the time. While you did ask for best dissipation and heat conductivity, I'd keep in mind cost and ease of use.
Dawn: When men of reason go to bed. ~Ambrose Bierce
Old 16th March 2004, 12:51 AM   #9
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Saphire is also pretty conductive. And it just so happens that's what anodizing produces on the aluminum surface.
I think aluminum is more conductive than copper by density; certainly by cost.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 16th March 2004, 12:52 AM   #10
I'm pretty sure I've seen that done before. Don't forget the thermal resistance between the copper-alum. interface needs to be minimized.
best metal for heatsinks?Hide this!Advertise here!
FS: Metal Case Enclosure, Inductors, heatsinks durwood Swap Meet 1 19th May 2009 01:28 PM
Metal dome should always go with metal cone? Is this a rule? Jay_WJ Multi-Way 5 5th February 2007 06:53 PM
where do you buy your metal?? sts9fan Parts 9 13th October 2006 08:56 PM
ASC metal can polypro caps: ground the metal can to AC ground? jarthel Parts 10 6th September 2006 12:54 PM
Metal Oxide vs flamme proof vs metal film ostie01 Parts 28 26th June 2006 06:38 AM
