Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 15th March 2004, 12:22 AM   #1
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Default Run opamp on single supply
Is it possible to run an opamp that was designed for +- supply on
single supply?
Old 15th March 2004, 01:28 AM   #2
HDTVman is offline HDTVman  United States
Yes, you can. You just need to provide a reference at 1/2 of the power supply voltage and use this reference in place of the ground for the opamp. This also means the you will need to cap couple the input and output.
Later BZ
What ever makes the tunes flow
Max voltage for single supply opamp Gunders Parts 2 19th November 2008 03:56 PM
Looking for some NS LME49710 Single DIP Opamp dtm1962 Swap Meet 0 4th September 2008 01:06 AM
Single supply opamp - unequal rail voltage and opamp selection Hans L Parts 8 19th February 2006 03:15 PM
Here is the single opamp attatchment aletheian Chip Amps 0 22nd August 2005 09:30 PM
Page generated in 0.05536 seconds (68.46% PHP - 31.54% MySQL) with 10 queries
