Inductor coil parasitic capacitance, using the cosh function - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 11th January 2017, 05:53 PM   #1
Default Inductor coil parasitic capacitance, using the cosh function
I have a formula for predicting the capacitance of an air core inductor.
Cparallel (pF per turn) = B * Er / {11.45*cosh^-1(S/D)}
where B = coil diameter mm
Er = dielectric constant (of air) = 1
S = gap between the coil turns mm
D wire diameter mm
I think cosh^-1 is the inverse cosh function.
Can I get a scientific calculator to give that answer, when S/D = 1?
If I press
2ndF, then hyp, then cos (1), I get 0
or
hyp, then 2dF then cos (1), I get 0
or
hyp, then cos (1), I get 1.54
Any idea if any of these answers could be correct?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 11th January 2017, 06:44 PM   #2
Waly is offline Waly  Umm al-Qaiwan
Waly's Avatar
D wire diameter mm
If I press
or
or
cosh(x)=(e^x+e^(-x))/2=(e^x+1/e^x)/2
If cosh(x)=1, then the only option is e^x=e^(-x)=1 (since y+1/y=2 has y1=y2=1 as solution), which in turn means x=0.
Old 12th January 2017, 05:28 AM   #3
Unfortunately that makes the C/turn to be infinity since the cosh^-1 is in the divisor.
regards Andrew T.
Old 12th January 2017, 09:38 AM   #4
DF96 is offline DF96  England
I guess that means the formula is wrong.
Is it possible that you have misunderstood the formula, and perhaps S is not the space between turns but the distance from wire centre to wire centre? That means that turns which are touching will have S=D, at which point you might expect quite high capacitance. Not infinite capacitance, but the formula probably only works when there is some space.
Old 12th January 2017, 09:47 AM   #5
I copied the formula from here and although they say that S = distance between , the drawing does show what you suggested. Centre to centre rather than gap/space.
regards Andrew T.
Old 12th January 2017, 09:50 AM   #6
Back to the question: how can I use a scientific calculator to find cosh^-1?
so that I can see comparisons of close spaced coils with wider spaced coils.
regards Andrew T.
Old 12th January 2017, 10:29 AM   #7
On my calculator (Casio fx-570) it appears that 'hyp' and 'inv' can be pressed in either order to get inverse cosh. I suggest you play around with a few known values (cosh itself is easy to calculate, as it is the average of two exponentials).
Old 12th January 2017, 10:46 AM   #8
My Sharp does the same:
hyp > 2ndF > cos (number) gives the same result as 2ndF > hyp > cos (number).
And for S/D = 1.005 (very thin insulation on touching coils) cosh^-1 (1.005) results in 0.09996
and for big gaps equal to wire diameter cosh^-1 (2) = 1.317
i.e. the capacitance has gone down by 92%. That's an enormous reduction in parasitic capacitance. But the inductance will also have gone down so I would need more coils pushing the capacitance back up a bit.
Thanks Waly & DF.
However there are a few discussions on calculating parasitic capacitance of single layer coils and there seems to be much disagreement on what formulae can be relied on to give sensible answers.
One formula gives Cparasitic = coil diameter * X
irrespective of the number of turns nor of the wire diameter.
regards Andrew T.
Old 12th January 2017, 10:47 AM   #9
Elvee is offline Elvee  Belgium
Elvee's Avatar
Back to the question: how can I use a scientific calculator to find cosh^-1?.
If it isn't on your physical calculator, you can use the windows scientific calculator:
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 12th January 2017, 11:10 AM   #10
Again, thanks.
I use the scientific Windows calculator and it loads up that way why I open it.
But I forgot to go and look !
And it gives the same answer, provided I enter the number first and then inv > cosh.
regards Andrew T.
Copyright ©1999-2017 diyAudio
