Signal direction of bulk Z-foil resistors - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 7th January 2017, 03:36 PM   #1
reaction's Avatar
Default Signal direction of bulk Z-foil resistors
Hi folks,
Is there anyone here who has tried to find the signal direction of the common types of Z-foil resistors (TX2575, Charcroft CAR, Z201) with reference to the resistive layer (nude types) or printed text 'Z201' (encapsulated type)? Left to right or right to left?
I have my own observations, but will share them at a later stage in order not to affect on your opinion.
Old 7th January 2017, 04:08 PM   #2
KSTR is offline KSTR  Germany
KSTR's Avatar
Z-foils are individually laser trimmed and we have no way of knowing how many of the shorting strips have actually been removed in a specifc resistor and at which positions along the foil. Since the trimming is the only possibly asymmetry found in Z-foils (otherwise the are of 100% symmetric construction) all bets are off that there could be a strategically better general orientation (that is, if you actually believe in such a thing, and even if when you do -- but remember audio is an AC signal -- then it would be circuit specific, so no generalized statements could be made).
Old 7th January 2017, 04:29 PM   #3
reaction's Avatar
I am talking about hearing, not believing
At my bench both directions behave differently as sonic subtleties (TX2575)
Old 7th January 2017, 04:39 PM   #4
Gopher is offline Gopher  United Kingdom
Then you're imagining it. Memory tricks - wanting to hear something so you do. Tell me - how do you switch between one resistor and another? Mechanical switch? Jumper? Soldering? Any of those is likely to have more of an effect than the resistor.
Old 7th January 2017, 04:47 PM   #5
reaction's Avatar
I am not a newbie who listens with eyes, believe me
Let's get back to the point
Old 7th January 2017, 04:59 PM   #6
DF96 is online now DF96  England
You are asking people if they have found something which does not exist. What is the point of this?
Even if these resistors were significantly asymmetric then which way the 'signal flows' would not be relevant; it would be which way the DC flows which would matter.
You are talking about "believing", but believing something which is not true.
Old 7th January 2017, 05:12 PM   #7
reaction - you still haven't told us how you switch the resistors in this test of yours from my previous post. Please enlighten us.
Old 7th January 2017, 05:12 PM   #8
I'm pretty sure that at any instant in time, current is flowing in one wire and out the other. Beyond that, I don't know what a sensible answer to the question would look like.
I may be barking up the wrong tree, but at least I'm barking!
Old 7th January 2017, 05:17 PM   #9
to which question are you referring Conrad?
Old 7th January 2017, 05:48 PM   #10
nightyj is offline nightyj  Bulgaria
Vishay TX2575 and Charcroft Z-Foil are different but they all has the same direction . I am using them as I/V as on the picture it is clearly audible and easy to catch. Left one is the Vishay TX2575 .
Metal Film vs. Bulk Foil resistors audiogeekess Parts 23 31st August 2016 08:03 AM
Vishay S102K Bulk Foil Super resistors cygnus x1 Swap Meet 1 26th August 2015 03:02 PM
VISHAY VTA 55 Bulk Metal Foil Resistors? phrarod Parts 3 11th August 2011 07:42 PM
Vishay bulk foil resistors - where to buy? sublemon Parts 2 22nd October 2005 05:15 AM
Black gate caps and vishay bulk foil resistors biovizier Parts 1 21st June 2005 04:20 PM
Copyright 1999-2017 diyAudio
