Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 11th March 2004, 09:25 PM   #1
punchpeanut's Avatar
Default How much current can this actually produce?
Hi again. I have seen circuits similar to this one in several places. U1 is a NE555 timer, used to invert 12V. On one website (the one I got this pic from), the author stated a max current of 280mA. That's sufficent for my needs. On the ESP site, a similar one is stated as having max current of 30mA. How much can I really expect out of one of these circuits?
Thanks.
Old 11th March 2004, 09:34 PM   #2
Electrons are yellow and more is better!
peranders's Avatar
I have a hunch of that Rod is closer to the truth
You can simulate this in LTSpice (freeware) and use a square wave source with a resistor in series to limiting the current. Just add a load also. Then you can see how the wave form will look like. You can also measure currents. This design to create negative voltage is rather ineffective.
/Per-Anders (my first name) or P-A as my friends call me
Old 13th March 2004, 08:50 AM   #3
jehaupt is offline jehaupt  United States
use this IC to invert a plus supply: ICL7662, available from www.newark.com.
Jim
Old 13th March 2004, 09:47 AM   #4
promitheus's Avatar
I have never measured that but I would say not more than 50 mA. ICs like the 555 can´t deliver much current.
Old 14th March 2004, 01:02 PM   #5
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
As I recall:
I-Sink: 50mA
I-Source: 100/200 mA
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 14th March 2004, 02:12 PM   #6
promitheus's Avatar
ACD nice website you got there.
Old 14th March 2004, 04:14 PM   #7
Jan Dupont's Avatar
Default promitheus
Old 14th March 2004, 05:41 PM   #8
roadkill's Avatar
This question's not easy to answer unless you know what kind of ripple you can tolerate at the output, typical of any unregulated supply. Use an LDO at the output if in doubt. And, as peranders has suggested, simulate.
Which tube? How much power can it produce? flysig Tubes / Valves 3 19th April 2009 08:05 PM
How much power to produce 10KW or more pjpoes Solid State 29 15th February 2008 03:12 PM
Anyone willing to produce X2-boards ? Blitz Pass Labs 1 14th March 2005 10:24 AM
DIY - Produce 10 Watts in 10 minutes destroyer X Solid State 43 16th November 2004 03:49 PM
Why can't sound produce light? tomasro Everything Else 62 1st February 2004 02:00 AM
Page generated in 0.19547 seconds (32.82% PHP - 67.18% MySQL) with 11 queries
