Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 10th March 2004, 07:47 PM   #1
Stocker is offline Stocker  United States
Question secondary voltage vs. primary voltage
Power transformer.
there are 100V and 120V primary wires. Ostensibly (by the label on the transformer) hooking up the 120 to my 120 mains will yield ~20V on the secondary. 6:1 yes? also, if 100V mains are used with the 100V primary, ~20V out. 5:1 yes?
So: will using the 100V primary winding get me ~25V on the same secondary, or just a big ~ZAP~ or somewhere in between? or have I got this all wrong?
Jesus loves you.
Old 11th March 2004, 03:35 AM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Yup. Mind that the transformer may be wound close to limits - that is, too much voltage lets out the magic smoke. I hesitate to say 20% shouldn't be a problem. (If it's a 50/60Hz unit ran at 60Hz I'll put in a bit more confidence. )
Tim
Seven Transistor Labs
Projects and Resources
Old 11th March 2004, 11:29 AM   #3
Thanks. Now if only the current capacity would stay the same...
Jesus loves you.
Old 11th March 2004, 05:38 PM   #4
Sch3mat1c's Avatar
It does! In fact, current capacity is entirely dependent on the wire; you could wind a 1 cubic inch transformer with superconductor and pass hundreds of amperes through it!
Tim
Old 11th March 2004, 05:42 PM   #5
Tim
Err..... I don't think so, the core must be able to maintain the
flux required for the secondary output, so presuming the core
saturates the 25V output will have less current than the 20V.
sreten.
Old 11th March 2004, 07:41 PM   #6
Sch3mat1c's Avatar
Actually, the primary's field cancels with the secondary's field (because they have an equal and opposite number of amp-turns) leaving the core only to deal with its inductance. That's why a transformer's primary only draws as much power as the secondary, plus a small idle magnetizing current equal to the primary's inductance.
Tim
Lundahll 1669A Secondary voltage??? Valvomaniac Tubes / Valves 1 5th April 2007 07:13 PM
How to lower the secondary voltage of a transformer myfavoritething Power Supplies 3 20th December 2006 10:30 PM
help with transformer secondary voltage reading jarthel Parts 6 17th September 2006 11:48 PM
Secondary voltage for heaters pengboon Tubes / Valves 3 1st February 2006 02:09 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
