Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 10th March 2004, 07:25 PM   #1
leadbelly's Avatar
Default Is solder a good heat transfer medium?
Sorry to crosspost, but it looked like my subject was not going to get an answer:
http://www.diyaudio.com/forums/showt...707#post345707
I want to use LM384's, which are DIP chips using the middle six pins for the heatsink connection. If I were to solder these 6 pins to a generic heatsink, would that be an acceptable bond for heat transfer to the sink?
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 10th March 2004, 07:40 PM   #2
If you can solder to a generic aluminium heatsink
then you get my Genius Of The Year award.
A copper heatsink is a better bet.
sreten.
Old 10th March 2004, 08:03 PM   #3
JonPike is offline JonPike  United States
Well, I've heard of, but never tried, using Asprin as a flux for Aluminum.
These kinds of chip are normally soldered down to a pc board, with a broad copper area connected to those pins as an on board sink. So yes, solder is fine, even though it dosen't conduct anywhere near as well as pure copper or Al.. It conducts a hell of a lot better than air!! There's just not that much heat generated in a small chip like this, so no worries...
As Sreten said.. copper would be easiest to work with.. go to the hardware or hobby store and see if you can find some copper or brass sheeting.. dosent have to be very thick (maybe .030" or more) and cut yourself a strip a inch or so long, wide enough to fit across the pins. Do some research to see if needs to stay isolated, or if it's grounded, etc... and keep it from shorting to anything else.. and your done!
I'll have to try that Asprin flux trick one of these days, though, and see if it really works.
Old 11th March 2004, 03:33 AM   #4
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Pffbbt. Soldering aluminum is easy, just pile on a glob of solder and rosin and scratch up the aluminum surface with the soldering (iron/gun) tip.
If that's too much, you could solder on heavy copper tabs to screw to the heatsink instead. Or install clips to hold the heatsink against the chip ala processor heatsinks.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Good, inexpensive stripping/tinning solder pot. Colescuttle Parts 0 25th September 2006 07:01 PM
as long as a solder is eutectic, does it mean it's good? jarthel Parts 2 16th September 2006 10:41 AM
Heat transfer sompound and mica , silpads etc dhole Pass Labs 1 29th April 2005 04:45 PM
Page generated in 0.07622 seconds (69.12% PHP - 30.88% MySQL) with 10 queries
