Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 28th November 2004, 08:10 PM   #41
jackinnj's Avatar
Originally posted by Peter Daniel
Interesting use of nuts istead of standoffs.
btw, there are a lot of sellers of standoffs on the Bay -- for a couple bucks you can get hundreds. (who needs hundreds?)
Old 28th November 2004, 08:28 PM   #42
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Actually I was admiring the creativity
Nothing wrong with mounting boards in this way.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 28th November 2004, 08:43 PM   #43
gmarsh is offline gmarsh  Canada
gmarsh's Avatar
It works, and it's very secure.
I do have standoffs, but there's a couple of problems...
- my standoffs are threaded
- a couple of the heatsink holes are drilled into fins, so I can only put a screw in from the amplifier side.
So if I put a screw in, I can either tighten the standoff against the amplifier PCB, or tighten it against the heatsink. Doing either will prevent the screw from turning so I can't tighten everything together all at once.
Using two nuts instead of a standoff means I can keep everything tight. And to the person that said I can get cheap standoffs really easily, I'd like to see you find an 8mm standoff that's as cheap as two M3 nuts.
Old 30th November 2004, 06:51 AM   #44
Default SMD Soldering Method
A nice SMD soldering method is to use a hot plate. Weller sells one and you can set the temperature of the hot plate to what the solder paste requires.
First, put solder paste onto the pads, and then put the SMD components on the paste, and then put the PCB on the plate.
As the PCB gets hot the solder will melt and the components will nicely be "sucked" to the center of the pad.
Just watch out for bent PCBs when heating them. One can put some heavy parts on the edges of the PCB so it stays flat.
Sigurd
Old 30th November 2004, 07:15 AM   #45
I find it hard to agree that SMD resistors are all bad. There are some very good SMD resistors out there. It is just hard to find them (and sometimes to buy them). They can be very expensive resistors but that is also the case with hole mounted audiophile resistors like Vishay S102k and Caddock MK132 and Riken resistors.
I am thinking about Vishay's SMD bulk foil resistors.
Here are some links to the VSMP resistors:
http://www.vishay.com/docs/63096/vsmp1206.pdf[/URL]
http://www.vishay.com/docs/63099/vsmp1506.pdf[/URL]
You can also see on this photo that even Mark Levinson is using SMD resistors for their attenuator board:
http://www.marklevinson.com/image_library/32AB_lo.jpg
That preamp sounds rather good according to the people who have reviewed it.
Sigurd
Originally posted by ingvar ahlberg
is still lousy resistors, You can find metalfilm resistors in melfpackages but nothing close to the quality of even the most comon through hole metal film resitors. SMD/SMT is all about producing high volume cheaply.
Old 30th November 2004, 12:05 PM   #46
jackinnj's Avatar
...and a lock-washer
Old 10th April 2013, 11:42 PM   #47
That surface mount slone 11.4 looks good. I'm assuming its in its case by now Maybe some more pictures and a board layout? Does it have any measurements done?
Surface Mount Packages cantskienuf Parts 0 6th November 2008 08:02 PM
what is this component? (surface mount) marko Car Audio 23 15th June 2008 07:38 AM
WT: OPA2604 Surface Mount 2x - Will trade DIP mount 2x Destroyer OS. Swap Meet 1 22nd December 2006 06:18 AM
Surface Mount Resistors Mermprin Parts 3 1st July 2004 07:19 PM
Surface mount is more fun than... PSz. Chip Amps 0 9th April 2004 10:43 PM
Copyright ©1999-2013 diyAudio
