Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#11 | |
![]() On tantalum caps dark bar means + |
#12 |
Electrons are yellow and more is better!
Why don't you look in the datasheet?
Normally the plastic foot has two cut corners = plus some sort of stripe at the can = negative Let me also point out that SMD parts are made for machine soldering.
/Per-Anders (my first name) or P-A as my friends call me Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 35 pcb's in interest. |
#13 |
Speaking of drilling holes unless it's for cell phones... I just read an article in a trade magazine discussing relative merits of bonding wire to terminals on the ICs that are stacked FOUR and FIVE tall inside cell phones
![]() anyhow- On some of our PCBs here at work, the surface mount caps have a stripe on one side that is oriented toward a "+" printed on the PCB. HTH
Jesus loves you. |
#14 | |
Ingvar |
#15 |
Jesus loves you. |
#16 | |
hello,
![]() It's useless to tear them apart.... I have checked out the structure diagram. The anode is almost symmetric to its cathode. really! ![]() ![]() Also, I don't think it gonna blow up if you reverse the positive and it negative. At most, the wrong positioning shorten the cpas life. That's it. CC ![]() |
#17 |
OK!!
The marked side is the cathode! This is the final conclusion after reviewing several SMD caps manufaturer's website. C.C. |
#18 | |
#19 | |
You can also solder SMD parts per hand - 0,2mm pitch is possible - although i got an hurting red eye after 500 pins ![]() Greetings Ralphono |
#20 |
I also use the hot air soldering equipment. comes useful for shrink tubing too.
![]() I only use hot air for resistors, IC's, transistors, ceramic caps. I always think electros and tants hate high temps. |
Thread | Thread Starter | Forum | Replies | Last Post |
Surface Mount Packages | cantskienuf | Parts | 0 | 6th November 2008 08:02 PM |
what is this component? (surface mount) | marko | Car Audio | 23 | 15th June 2008 07:38 AM |
WT: OPA2604 Surface Mount 2x - Will trade DIP mount 2x | Destroyer OS | Swap Meet | 1 | 22nd December 2006 06:18 AM |
Surface Mount Resistors | Mermprin | Parts | 3 | 1st July 2004 07:19 PM |
Surface mount is more fun than... | PSz. | Chip Amps | 0 | 9th April 2004 10:43 PM |
New To Site? | Need Help? |
