Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 8th March 2004, 01:32 AM   #1
Default mains wiring
I need to run wires from my power jack to my tranny on my AKSA 55. I have some unmarked 16 guage stranded copper wire. Is this safe to use or do I need something more specialized?
Can I also use this after the bridge to take DCboards?
I can't believe the wire has no markings on it.
Old 8th March 2004, 01:41 AM   #2
leadbelly's Avatar
Yes, it is safe to use. By the way you phrased your subject and question, I'm guessing you think the AC wiring inside your amp is subject to the National Electrical Code as "mains wiring". It isn't.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 8th March 2004, 01:44 AM   #3
No, I'm just paranoid about connecting a plywood box to an electrical outlet and burning my house to the ground.
I misused the term. I probably should have said primary wiring instead.
Old 8th March 2004, 01:54 AM   #4
leadbelly's Avatar
Ooooh, you really should throw some metal in there to ground the AC components to. Maybe just a little plate inside the plywood.
Old 8th March 2004, 01:59 AM   #5
I will. The front and rear panels are aluminum and the power switch and iec socket are mounted on the rear plate.
MAINS... simple, old style amplifier, plugged into mains electrical outlet (110) destroyer X Solid State 2 15th June 2008 02:31 PM
Chaning transformer wiring from USA to UK mains A Sanchez Power Supplies 4 3rd June 2008 10:37 PM
cap across mains switch? klitgt Power Supplies 4 11th December 2006 08:27 PM
Focusing on wiring cable for gainclone!!!Share ur experience in wiring cable.... thomgun_lc Chip Amps 38 31st August 2005 02:46 PM
I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) Audiophilenoob Chip Amps 9 16th August 2005 04:37 AM
Page generated in 0.08228 seconds (72.96% PHP - 27.04% MySQL) with 10 queries
