| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
When a manufacturer specifies a load capacitance what exactly does this mean.
I know that you connect two capacitors from the crystal legs to ground. But if they state a value of 30pf does that mean use two 15pf or two 30 pf? The data sheets for the make ive found are useless. Cheers Matt
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
#2 |
Someone? Anyone?
#3 |
It means the effective capacitance across the crystal. For the case you mention where you want a 30pf load, then you need to remember that the two capacitor to ground are effectively in series. To get a 30pf load would require a 60pf cap to ground from each leg.
Of course you also need to consider the capacitance provided by the rest of the circuit and adjust accordingly. More capacitance will pull the frequency slightly higher. ---Gary |
| Capacitor Comparison Conundrum | bereanbill | Tubes / Valves | 12 | 28th May 2009 09:00 PM |
| step attenuator conundrum | tl507083 | Parts | 5 | 7th May 2007 03:40 PM |
| The Subwoofer Conundrum | kingdaddy | Subwoofers | 5 | 13th May 2005 02:07 PM |
| MC275 Hum Conundrum | rkic | Tubes / Valves | 0 | 4th July 2004 10:41 PM |
| Symmetrical amplifier conundrum | Kilentra | Solid State | 22 | 31st January 2003 05:06 AM |
| Page generated in 0.07702 seconds (71.78% PHP - 28.22% MySQL) with 10 queries |
