Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Chassis wire
Chassis wire
Old 26th October 2017, 09:14 AM   #11
DF96 is offline DF96  England
Originally Posted by DualTriode
Why was silver plated teflon insulated wire specified for aerospace?
I would need to Google to find out, but my guess is that teflon is fire-resistant - useful in areospace; possibly PVC can creep if put under pressure. Silver plating good for VHF and above. Certainly nothing to do with audio quality!
Old 26th October 2017, 03:57 PM   #12
DualTriode is offline DualTriode  United States
I took you suggestion and went to Google.
PTFE vs. PVC has greater resistance to heat or melting, is less flammable and generates less smoke.
Silver vs. copper has ~ 6% greater conductivity or conversely copper has ~ 6% greater resistance than silver.
Proponents of PTFE insulated silver plated wire claim sonic improvements over copper wire due to skin effect.
For a discussion of skin effect at audio frequencies see this Belden link. Understanding Skin Effect and Frequency
Skin effect does not come into play at audio frequencies.
DT
Old 26th October 2017, 05:21 PM   #13
rayma is offline rayma  United States
Originally Posted by DualTriode View Post
silver plated teflon insulated wire does not benifit audio but has application for UF.
When Teflon insulation is used, silver plating on the copper is necessary to prevent oxidation.
Old 26th October 2017, 05:47 PM   #14
Is that because of the potential reaction between copper and PTFE. Or that both PTFE and silver are both better suited to harsh environments than PVC insulated bare copper.
In air plenums where fire and smoke are the primary issue PTFE insulated copper cables are not uncommon.
DT
Old 26th October 2017, 07:57 PM   #15
It's because of the high temperatures involved in the mfg process.
Old 26th October 2017, 09:14 PM   #16
Thanks for that information.
Old 27th October 2017, 10:36 AM   #17
So the only reason to use teflon coated silver plated wiring in audio is to get less smoke under serious fault conditions. Even aerospace doesn't use silver plating for electrical reasons. As SY used to point out (he is an expert on these things), teflon on silver is a bad combination for triboelectricity so such cables might be microphonic or suffer from handling noise - so a poor choice for audio, especially low level signals.
Old 29th October 2017, 10:30 PM   #18
Default Has anyone tested silver plated Teflon insulated hookup wire?
Hello,
I am not ready to trash my newly found stash of silver plated copper Teflon insulated hookup wire.
Has anyone tested the claimed possible negative effects of silver vs Teflon or on the other side the claimed brighter effect of silver plated copper vs copper alone?
DT
Old 30th October 2017, 06:07 AM   #19
50AE is offline 50AE  Bulgaria
Chassis wire
I've noticed that under higher than room temperature, copper wire near well biased tubes within a PVC insulation tends to develop a greenish, copper chloride patina. The resulting copper wire appears to be more mechanically fragile.
A possible explanation is that PVC tends to break down at higher temperatures, releasing chlorine and the later reacts with the copper metal. It's used as a chlorine donor in colored pyrotechnic mixtures after all.
Teflon on the other end, can release fluorine gas which is not a lesser evil, but this happens at higher temperatures than PVC.
As for the silver coated copper wire, lots of us folks subjectively detest it for the known, brightly harsh sound in the midrange domain.
Old 30th October 2017, 10:35 AM   #20
Physics says that silver wiring will sound exactly the same as copper wiring. I am not aware of any tests (electrical measurements or ears-only listening) which show anything else. However, there are lots of anecdotes about silver wiring sounding bright and copper sounding dull; the correlation between these descriptions and the surface appearance of the metal may be pure coincidence.
Chassis wireHide this!Advertise here!
Chassis Wire Sources wanders Parts 3 2nd May 2016 10:23 PM
FS: some extra Vampire Wire hookup/chassis wire cdfac Swap Meet 4 10th February 2013 06:16 AM
Hook-up/chassis wire EvilYoda Parts 4 8th August 2007 08:31 PM
magnet wire (not sure of the term) used as chassis wire? jarthel Parts 8 27th September 2006 09:50 PM
chassis wire Evaas Parts 6 17th February 2003 03:51 PM
