| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Are they better for some reason ?
#2 |
"Although significantly heavier, tin foil is generally preferable to aluminum foil, although the degree of improvement is debatable. Presumably, this is due to fact that tin is softer, resulting in less residual stress and reduced susceptibility to microphonics."
Lots of info here: http://ldsg.snippets.org/appdx-ec.php3 I doubt its much better (than al foil), maybe if you want the "best". |
#3 |
Good site overall, but why does he keep saying that polystyrene has a lower dielectric constant than polypropylene when the opposite is true? Polystyrene has a K of 2.5-2.6; polypropylene has a K of 2.1-2.2 and teflon has a K of 2.0 - 2.1.
Aside from this, it looks like a very informative site. |
#4 |
My idea was that in the case of tin foil caps, the leads may be directly soldered to the foil.
The contact to aluminum is always questionable. And its different materials which might make a "battery". |
| Silver Foil Paper in Oil Caps | precisioncaps | Vendor's Bazaar | 0 | 11th March 2007 02:12 PM |
| Replace electrolytics with foil caps? | Nordic | Parts | 3 | 24th March 2006 02:35 PM |
| Chinese foil caps? | aarsoe | Parts | 12 | 18th March 2005 09:23 AM |
| Need good foil Caps for rails | abpea | Chip Amps | 3 | 8th January 2004 04:34 PM |
| inexpensive film and foil caps | mm | Parts | 3 | 27th April 2003 06:29 PM |
| Page generated in 0.19304 seconds (32.78% PHP - 67.22% MySQL) with 10 queries |
