Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 4th March 2004, 08:44 AM   #1
Default Battery Layout for PSU
I am working on a battery PSU for my gainclone. It will have two 12V SLAs in series for each of 4 rails. I would, for obvious reasons, like to avoid having to use a charger for each battery or even rail.
First, can I charge two in series as I would one without determent to either of the batteries? Will one battery get a smaller share of the charging current? Does having one battery draw current through another battery degrade the latter? If there is a reason to charge them separately then should a simple resistor divider between batteries and charger suffice? If this isn't the case am I not right in thinking that I should use 24v with varying amperage (as necessitated by the type of charging being done) but with the resistor/divider I should use 12v/with twice the previous amperage?
For that matter, can I use a resistor divider after the batteries so that I can split 4 batteries charging in series into 2 24v ?
Old 9th March 2004, 09:23 PM   #2
medum is offline medum  Denmark
medum's Avatar
Default Re: Battery Layout for PSU
Originally posted by LeoBloom
........Will one battery get a smaller share of the charging current? Does having one battery draw current through another battery degrade the latter? If there is a reason to charge them separately then should a simple resistor divider between batteries and charger suffice? .............
"multiplexer"
You should charge each battery separately for the reasons you mention. I've made a kind of multiplexer, that will charge a series of SLA's one by one in a cyclus of 4x15 minutes appr. You can use one charger to charge 4 batteries this way - see my thread and look for post #18.
Eagle vs. Sprint-Layout for PCB design/layout hollowman Parts 9 9th July 2011 05:34 AM
+/-18V & +48V from a battery jeppix Power Supplies 23 20th November 2009 05:26 AM
Battery Charger for 15V Li-ION Battery Pack ??? Jan Dupont Parts 2 11th April 2009 03:18 PM
Regulator for Battery ?? redrabbit Power Supplies 10 2nd July 2008 01:48 AM
Battery VoLCoM Parts 1 17th August 2003 09:45 AM
Page generated in 0.07445 seconds (69.78% PHP - 30.22% MySQL) with 11 queries
