Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 1st March 2004, 09:59 PM   #1
leadbelly's Avatar
Default Can dissimilar xfrmr secondaries be wired in parallel?
I do not think I have seen this information discussed.
Say you have a transformer with 2 dissimilar windings. Can these be wired in parallel? What is the result? One secondary is rated W VAC @ X A, the other Y VAC @ Z A.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 1st March 2004, 11:13 PM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Depending on phase, you get a current equal to W + Y or W - Y volts across the total resistance of the windings. Current rating has no bearing here, as the only price paid in drawing excessive current from a transformer not rated for it is resistive heating in the wire and severe voltage droop (for the same reason).
(And yes that means you could make a 1kW transformer fit into a wall wart if you had enough liquid nitrogen and a few thousand turns of superconductor wire. The only dissipation would be that of the connecting wires and hysteresis/eddy current losses in the core!)
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 1st March 2004, 11:47 PM   #3
leadbelly's Avatar
Shouldn't it be (W+Y)/2 or (W-Y)/2? How else would the case where W=Y (identical secondaries) result in a doubling of the current rating and no change in voltage rating?
Old 2nd March 2004, 01:20 AM   #4
Warp Engineer
On Holiday
AudioFreak's Avatar
For all intents and practical purposes, that is more or less correct.
- Dan
Old 2nd March 2004, 02:57 AM   #5
Sch3mat1c's Avatar
When W=Y, W-Y = 0 and there is no current flowing between the secondaries. Current ratings will add. If they are unequal, the higher voltage winding ("HV") will supply current to both the lower voltage winding ("LV") as well as the load, until the load becomes significant enough to draw HV's voltage down to LV's level. At this point a positive current will be drawn from LV (before, HV was pushing current into LV), but HV still dumps most of the load current.
I should clarify my earlier post by adding that's why it is a bad idea to parallel transformers. Remember that PT's are transformers as much as OPTs, in case you're paralleling those.
Tim
Old 2nd March 2004, 03:21 AM   #6
tiroth is offline tiroth  United States
The simple answer is no. Even in the case of identically rated secondaries, you can't parallel them unless their values were controlled at the factory to be identical. Otherwise you get enormous circulating currents through the low impedance secondaries.
Three 10" 4Ohm subs, wired in series or series-parallel? Nagamitsu Car Audio 24 10th May 2009 03:24 AM
Parallel secondaries barendh Parts 14 15th April 2007 02:13 PM
OpAmps wired in parallel Alfetta87 Digital Source 7 20th August 2006 07:57 PM
Wiring secondaries of two power trafo's in parallel? Klimon Tubes / Valves 5 21st October 2005 01:22 AM
Tranny: "Parallel" Secondaries dobbeln Parts 3 24th January 2005 02:32 PM
Page generated in 0.08138 seconds (75.32% PHP - 24.68% MySQL) with 10 queries
