| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi, I have been trying to create a drill file rack and position list in eagle to send off to get some PCBs made, and I'm having trouble getting two coherent sets to be produced that I can check in GCPrevu before I send them off to the board house for production.
Does anyone know any way of creating a set that I can check, or perhaps just getting GCPrevu to recognise the exisiting ones that I have produced (so far, I have what seems like the best results using the drillcfg.ulp then running the exccelon cam job, but I can't seem to open this with anything, so I ahev no way of checking the files are ok).
#2 |
You need to run excellon.cam from list under cam jobs. This will get you a set of coordinates, that along with your tool list is a complete set of drill data. I can test your complete data set for you if you me want to. Hope it helps you \Jens |
| Eagle won't change drill sizes! And double sided boards... | cuibono | Everything Else | 1 | 21st November 2007 11:52 PM |
| LM4780 SMD PCB - Eagle Files...are multilayer... | DJ Exprice | Chip Amps | 10 | 6th December 2006 03:12 AM |
| Eagle: Mirror bottom layer for Gerber files? | orthoefer | Everything Else | 4 | 17th August 2006 12:38 AM |
| Question about Eagle and Gerber-files... | CJ900RR | Everything Else | 2 | 9th August 2006 12:08 AM |
| Eagle files | Audiofanatic | Pass Labs | 8 | 30th January 2003 08:47 PM |
| Page generated in 0.05945 seconds (67.98% PHP - 32.02% MySQL) with 10 queries |
