Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 1st March 2004, 10:24 AM   #1
AKSA is offline AKSA  Australia
Default High Voltage Electros
Folks,
Does anyone know of a supplier of 1000VW electros?
I'm looking for about 100uF.
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 2nd March 2004, 09:52 PM   #2
djmiddelkoop's Avatar
The highest voltage I have come across for electros is 600V and thats pretty rare already.
To my knowledge it is not possible yet to go any higher than 600V with the materials used.
The only option you have is to place two 200uF 550V in series combined with two resistors for voltage division.
Dick.
Music is the best F.Z.
Old 5th March 2004, 06:22 AM   #3
I have seen 100uF 800V here in Tokyo, was a bit surprised I also thought that 500V maybe 600V was the limit so it is possible that these 800V units contains double caps but they look like ordinary elyts. I can check brand name next time I go to Akihabara, I work only 2 stops from there.
Regards Hans
Old 5th March 2004, 03:19 PM   #4
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Even then, for the 600-800V's they just connect two in series internally. Might as well use two 500V, or better yet, three 400V caps.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
High voltage, high current super regulator, possible group buy peranders Group Buys 54 2nd June 2009 09:43 AM
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 08:05 PM
high frequency high voltage power supply... moray james Planars & Exotics 6 23rd July 2008 07:57 PM
6BY5 High Voltage & High Current Choke Input Design P.S. snoopyma Tubes / Valves 7 28th June 2006 01:32 PM
Page generated in 0.08056 seconds (72.36% PHP - 27.64% MySQL) with 10 queries
