| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hello,
I would like to know how to regulate a HV/HT line with the LM3x7 series. I konw I can do so by raising the ground with the use of a zener and have seen a few schematics employing this method, but I'm still not certain what the true generic schematic is like. Those I have seen seems to be 'upgraded' versions. All versions would be much appreciated. Thanks! Cheers, w00t |
#2 |
It's a bad idea because they only have a range of maybe 40V input. Thus your power supply needs good regulation anyway, because at no-load you have an absolute maximum of say 290V versus a minimum of 250V. A very tight range for anything. Not to mention a 10% variation in line voltage (which is within spec) will take up most of that range.
Better to use a purpose-made HV regulator, either discrete or integrated. Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#3 | |
Banned
See the Linear Technology app note 2 http://www.linear.com/pdf/an2.pdf. Figure 11 and the text above it shows how to use the LT317 in a high-voltage configuration. |
#4 |
Just to give an example :
The transistor takes care of the input voltage which otherwise is out of scale, read destroy the 317. The voltage across the 317 is determined by the zener minus the Vbe of the transistor = approx. 6V. I have used this many times and it works very well as long as the output is not shorted to ground. Dick.
Music is the best F.Z. |
| Improving the LM3x7 regulator circuit | Geoff | Power Supplies | 158 | 8th January 2012 07:08 PM |
| Regulated PS with LM3X7 ? | kacernator | Solid State | 0 | 13th March 2009 04:04 PM |
| LM3X7 Supply | zei | Power Supplies | 25 | 23rd December 2007 06:52 AM |
| Heater Supply using LM3X7 current source | Tomo | Tubes / Valves | 10 | 1st June 2005 11:38 AM |
| LM3x7 Datasheet Error? | richie00boy | Parts | 5 | 7th July 2004 08:32 PM |
| Page generated in 0.08766 seconds (72.66% PHP - 27.34% MySQL) with 11 queries |
