Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Oil Capacitor needs forming ?
Old 28th February 2004, 03:34 AM   #1
djmiddelkoop is offline djmiddelkoop  Netherlands
djmiddelkoop's Avatar
Default Oil Capacitor needs forming ?
I have got these nice big 2uF 3500V oil caps which I want to use in series for a 5kV powersupply for my new direct drive ESL amp.
But I don't know if these caps need to be formed when using at such high voltages.
thanks in advance,
Dick.
“Information is not knowledge Knowledge is not wisdom
Wisdom is not truth Truth is not beauty Beauty is not love Love is not music Music is THE BEST”
Old 28th February 2004, 04:18 AM   #2
On Hiatus
SY's Avatar
In a word, no. They are not polar caps.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 28th February 2004, 09:47 PM   #3
Thanks Sy,
does this mean I can use it right away i.e. applying full voltage at once without any explosions ?
Dick.
Old 28th February 2004, 10:05 PM   #4
R.I.P.
AFAIK you need to add resistors in parallel
to the caps if you put them in series.
I don't really know how you calculate the
values of "safe" resistors, I presume the
purpose is preventing excessive voltage
across one of the capacitors.
And that this practise is only applicable to
power supplies, it can't be applicable to
general series capacitor use.
AFAIK only electrolytic capacitors need to
be formed before being placed in series
to form "bipolar" capacitors.
I'm sure if you reposted under tube amps
you''d get a definitive answer, hopefully.
sreten.
Old 28th February 2004, 11:00 PM   #5
On Hiatus
SY's Avatar
What sreten said: you do need equalizing resistors across the caps if you're going to put the caps in series. Given the low leakage of caps like the ones you're using, they can be pretty high value resistors; figure a milliamp or so of draw to be perfectly safe, though you could probably get away with less. For a milliamp at 2500 V (your B+ cut in half), 2.7 meg is the closest standard value. They'll need to be 4 or 5 watts and able to withstand the voltage. Frankly, you could probably use 10 megs, which would cut the power requirement down by a factor of 4.
If there's a dielectric resistance spec available for your caps, figure that any resistance a decade lower will probably do.
Old 29th February 2004, 12:33 AM   #6
Cybergent is offline Cybergent  Germany
... and the resistors need to be rated for the voltage. Otherwise you get a break thru.
Best Regards,
Cybergent
Old 29th February 2004, 12:01 PM   #7
Thanks for the answers, guys.
I have high voltage Caddock 20Mohm 1% 4 or 5 Watt resistors which I will put in parallel with the C's to divide the voltage neatly between them.
My concearn is mainly that these oil C's are NOS and so never used. Does these big metal can oil C's have a shelf life or in other words do they need a special treatment, like electrolytics, before applying power for the first time.
Because these voltages are so high and dangerous, I want to be on the safe side.
Dick.
Old 29th February 2004, 12:23 PM   #8
On Hiatus
SY's Avatar
Oil caps seem to have a very, very long life. The ones in my proto DD-ESL amp originated in my old ham rig; they were old when I built that rig 35 years ago.
Check the voltage rating of those Caddocks. You don't need precision resistors, but it's not like that will hurt anything, it's just a bit of a waste.
And you're 100% right to be cautious every step of the way. This is more voltage than Florida uses to execute murderers.
Old 29th February 2004, 07:50 PM   #9
What voltage are they using? AC or DC?
Just curious....
Best Regards,
Cybergent
Old 29th February 2004, 10:23 PM   #10
On Hiatus
SY's Avatar
It doesn't matter because they're using silver interconnects.
Oil Capacitor needs forming ?Hide this!Advertise here!
Forming main inductor for high-power boost converter Bootstrapper Power Supplies 1 31st October 2008 03:12 AM
"Re-Forming" Caps on Old Tube Amp DreadPirate Tubes / Valves 6 29th January 2007 08:58 PM
Air gap capacitor 2litre Everything Else 4 18th January 2007 03:09 AM
amplifier and rail-splitter forming a filter? Dominique Solid State 12 2nd May 2006 07:26 AM
Forming Cap's question.. Notorious Parts 7 28th October 2004 08:18 PM
Copyright ©1999-2017 diyAudio
