Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 28th February 2004, 12:38 AM   #1
Default mains voltage fluctuating
mains voltage fluctuating to much here on our area. any possible solutions to overcome this. thanks for your help.
Old 28th February 2004, 01:33 PM   #2
Da5id4Vz's Avatar
Send a message via AIM to Da5id4Vz
Have you considered something like a constant voltage transformer? They are also sometimes called boot buck transformers.
These guys posted a nice schematic:
http://www.aelgroup.co.uk/hb/hb511.htm
Two secondary, as the primary voltage fluctuates the output of the secondary averages their values.
Old 28th February 2004, 01:38 PM   #3
jackinnj's Avatar
the easy way is to get a generator of your own and mount a better muffler on the thing --
occasionally there will be Sorensen and Hewlett Packard AC constant voltage sources on EBay -- these can run from a few hundred dollars to many thousands.
here in New Jersey we have Third World Electric Co. as our supplier -- inthe summer the voltage can range from 102 to 127 VAC.
LED on mains voltage? AndrewT Parts 32 21st June 2011 09:04 AM
Kenwood KAC 848 rail voltage fluctuating zeppo4 Solid State 0 13th October 2008 02:00 AM
Taming mains voltage cbutterworth Power Supplies 2 16th September 2007 03:50 PM
Carver AV-405/AV-505 mains voltage rt_jensen Solid State 0 25th April 2005 03:03 AM
mains voltage stabiliser GAK Everything Else 1 10th April 2001 07:14 PM
Page generated in 0.07517 seconds (69.40% PHP - 30.60% MySQL) with 11 queries
