Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 26th February 2004, 04:53 PM   #1
Send a message via MSN to officeboy
Question 480/240V transformers
I see a lot of auctions for industrial control transformers on ebay, some of which go for pretty cheap.
They are usually 240/480 primary, and 120V secondary.
If i were to wire one of these up for 480, and put 120 from my mains there, would i get the expected amount of voltage drop on the other end? Like 30V? I realize the VA would change quite a bit as the amp rating would not change, so a 200VA transformer would then be a 48VA one.
Thanks.
110v Transformers for 240v Puffin Solid State 6 18th April 2008 07:48 PM
Simple method for 240V from 240V line eeyore Tubes / Valves 10 14th June 2007 10:42 PM
Two 120V transformers in series for 240V ? Bernhard Power Supplies 8 22nd November 2005 12:28 AM
240V DIY'ers, Please help AdamZuf Solid State 4 14th September 2004 04:35 AM
Using 120V transformers with 240V supply Peter Daniel Solid State 12 21st January 2003 12:32 AM
Page generated in 0.06625 seconds (70.22% PHP - 29.78% MySQL) with 10 queries
