| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Working on a MF A1 amp changing all the caps and the power transistors,the question is what is the proper way to solder the transistors ie collector to the case,as it would take abit of heat to solder them(worried about what the heat could do).I would have thought to use solder lugs to the mounts especially for the collector.At the moment they are soldered to the case.
Are there any advantages or disadvantages by doing this. Cheers |
#2 |
Usual method is solder lugs under mounting bolts. I doubt whether you will get solder to take properly to the case. If you are concerned about reliability of connection, the you could use lugs under both mounting bolts (assuming TO3 style).
Cheers |
| old RCA transistors- what are they? | needtubes | Parts | 10 | 14th June 2011 03:49 AM |
| what transistors to use? | prorms | Solid State | 1 | 20th November 2006 05:14 PM |
| Best transistors | YUTK | Solid State | 1 | 20th May 2005 04:16 PM |
| transistors | Dj BASS AMP | Solid State | 1 | 31st March 2003 04:46 PM |
| transistors | lemondog | Swap Meet | 5 | 1st March 2002 07:05 PM |
| Page generated in 0.06077 seconds (65.29% PHP - 34.71% MySQL) with 10 queries |
