| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi all,
I have some surplus Rifa PME 271 M X2 0.1uF caps rated at 250VAC. Are these caps suitable for replacing the snubber cap.? I realise most snubber caps. schematic rating the snubber at 630V. Thanks! Cheers, dreamie |
#2 |
What is your transformer voltage?
Hjelm |
#3 | |
Thanks. |
#4 |
250V AC is 630V DC in most caps.
If it sounds good... it is good! |
#5 |
The voltage should not be a problem then!
Hjelm |
#6 | |
Thanks! Guess I would be able to use this even in tube PS... |
#7 | |
| snubber p.s. | wicho | Chip Amps | 11 | 21st October 2008 01:07 PM |
| 2x 2Sk170 in place of 2SK389 and 2x 2SJ74 in place of 2SJ109? | jarthel | Parts | 12 | 26th July 2007 09:08 AM |
| Snubber AND non-snubber ? | jimbo1968 | Chip Amps | 10 | 6th December 2005 07:49 AM |
| Snubber | s2kov | Tubes / Valves | 13 | 30th November 2004 02:09 PM |
| Best place to place bleeder resistor in a power supply? | G | Tubes / Valves | 13 | 4th August 2004 09:26 AM |
| Page generated in 0.08426 seconds (75.25% PHP - 24.75% MySQL) with 10 queries |
