| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#11 |
When I started the thread I thought I was bringing something worthwile to everyone's attention.
Now the jury seems to have come in. At least the thread reader's won't be wasting their money on that item. |
#12 |
#13 |
Ciscokid - and how does it work and sound?? Does it pop between switching?? Or are/were you satisfied with it??
#14 |
Yes, as mentioned in my previous posts. I have a pair of mono blocks and use one pot in each. One of the first set developed a pop within a few days of use. I ordered a second set thinking that perhaps one of the first was bad. After replacement through, still had the popping between clicks between about 9:00 and 11:00 on the dial. The other monoblock has started popping too, however not as bad just annoying.
Hope this helps.. ck |
#15 |
Thanks Ciscokid
I will try mine today (hehe - yesterday I bought one in the afternoon - glad to get an Alps for a quite reasonable price - in the eveneing I've find out this topic - so now I'm a bit sceptical - but - if it won't pop - then it was a good investment) and report how does it perform ... Btw - Ciscokid - is it hard to dismantle it?? Are ther any "tricks" I should know if I will have to do it?? Thanks again |
#16 |
Hmm, I wonder if widening that copper contact patch would help give it a better connection to the contacts on the wafer.
Oh well, guess I better play it safe, and stick with the crappy pots I have, at least they don't pop and click. |
#17 | |
Account Disabled
Because no matter how good a pot you have, they will pot sometimes. and it is always a risky proposition to NOT consider that when you engineer the design. |
#18 |
Millwood makes a good point.
If we consider a pop a component failure then we should protec against the failure. A shunt across the pot would prvent this at the sacifice of the gain range. Of course, as I speak I design so changing the input resistors would compensate for this.
Bill Strum Bstrum@imagematics.com |
#19 |
So - after comming home - I just couldn't wait till GC will be finished - I've implemented Alps (or whatever it is) stepped attenuator in a passive preamp - so right now there are his first minutes ..
I will not judge sound yet; Does it pops?? Yes - the right channel sometimes does - but to hear it - there must be one condition to hear it: - you must switch it very very slowly But then again - it pops very very quiet - considering that the cheapest version of 2x12position attenuator I intented to use was almost the same price - but it also poped real loud - this Alps (or whatever it is) is worth of the money ... OK, I will wait and see what will happened in the future ... |
#20 |
Gawd, I bought one too.
It was for a Foreplay project. I feel so ashamed, & dirty. speaker |
| Which pot? Noble or Alps? Or another? | deiksac | Parts | 1 | 12th May 2007 05:47 AM |
| ALPS Pot | Brap | Tubes / Valves | 5 | 8th April 2004 12:31 PM |
| WTB:alps | sma | Parts | 1 | 13th December 2003 06:10 PM |
| ALPS pot | Mikael Abdellah | Parts | 6 | 21st April 2003 12:31 AM |
| Alps Stepped Attenuators on Ebay | Shoog | Everything Else | 0 | 11th April 2003 08:10 PM |
| Page generated in 0.10716 seconds (78.56% PHP - 21.44% MySQL) with 11 queries |
