Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 23rd February 2004, 10:47 AM   #1
Alcaid is offline Alcaid  Norway
Alcaid's Avatar
Default Help choosing opamp for active filter
Which opamp would you prefer using at a ±6 to ±7.2V (Split supply from car-battery buffered with BUF634T)? It will be used in an active crossover for my car.
I have some OPA2134 and OPA2604, but are there any opams that are better performers at this low supply voltage?
Any help or input appreciated.
PSU schematic:
Old 23rd February 2004, 05:13 PM   #2
Electrons are yellow and more is better!
peranders's Avatar
Have you checked AD8610 and AD8620? Only SOIC8.
/Per-Anders (my first name) or P-A as my friends call me
Old 23rd February 2004, 08:58 PM   #3
Alcaid's Avatar
I would rather prefer to avoid SOIC.
Old 25th February 2004, 06:44 PM   #4
BStrum is offline BStrum  United States
Default AD825 on batteries
I've built a preamp run off two 9v batteries using the AD825s
It sounds great. The batterey (quite DC source) made a big difference.
These can be run as low as 5 volts.
I'm curious why Alcaid would want to avoid SOIC.
I used BrownDog adapters to dip and about five minutes of eyestrain to mount three 825s.
Many new designs are only available on SOIC.
Bill Strum
Bstrum@imagematics.com
Old 25th February 2004, 08:33 PM   #5
Alcaid's Avatar
Default Re: AD825 on batteries
It's because my soldering skills isn't very good
SOIC will be tested later when the skills have bettered.
Old 25th February 2004, 09:50 PM   #6
Default Fear not SOIC
My soldering skills are only average. And i was not sure that I could pull it off at first.
The Browndog adapters where very well tinned.
I used an aligator clip to hold the chip in place on the adapter. used flux (as recomended by Browndog) and silver solder.
It was actully very easy. A magnifying glass and a small tip on the soldering iron make it even easier.
"Dare to struggle - Dare to win"
That was either Walt Disney or Mao Tse Tung, I forget who.
Bill Strum
Need help choosing op amp for active crossovers and preamp Jonathan Z Solid State 20 31st August 2010 11:49 PM
Choosing Amps for a 5 Way Active Horn System KCCT82 Pass Labs 32 26th April 2009 12:21 AM
Opamp for active filter and preamp tpsorin Chip Amps 9 7th April 2008 07:23 AM
Choosing an opamp for guitar direct box. Giora Parts 5 18th June 2007 12:38 AM
Choosing drivers for LR active crossover goldyrathore Multi-Way 4 24th May 2004 08:36 PM
Page generated in 0.08876 seconds (75.69% PHP - 24.31% MySQL) with 10 queries
