Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
SMPS Idle Current
SMPS Idle Current
Old 20th February 2004, 03:01 AM   #1
cm961 is offline cm961  Canada
cm961's Avatar
Default SMPS Idle Current
Hi guys,
I'm debugging this car audio amp. The idle current is about 1 amp or more. I'm not sure if ALL of this power is being dissapated in the main transformer, but it does get quite hot (not too hot to touch, but still really hot).
I thought SMPS are supposed to be very efficient. Is there something wrong with this one or is it normal? The amplifier does work but needs new input filter capacitors. However, when I connect these capacitors the amplifier becomes unstable. Without them it functions fine. I doubt it would work in a car environment though, compared to the 12V provided by my bench supply.
Any comments greatly appreciated!
Thanks,
Pete
Old 20th February 2004, 04:52 AM   #2
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Probably hyseresis loss or something. It's a "background" condition and is about constant whatever the power level is. Considering most such car amps are over 200W output, it sounds like the PSU is running right where it should be. (Maybe... 80% efficiency?)
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 20th February 2004, 05:56 AM   #3
cm961's Avatar
Ok thanks for the reply.
The amp seems to work fine. I was only able to test up to about a 2A current draw from my lab bench supply. When I have time I will purchase a better soldering iron that can actually make proper connections. Then I will be able to package the amp back up and test it inside the car. Right now the capacitors are connected with clip leads...
Pete
SMPS Idle CurrentHide this!Advertise here!
Idle current adjustment for NAD gvelim Solid State 0 5th August 2008 03:56 AM
JL AUDIO 250/1 idle current Pioneer621 Car Audio 2 24th April 2008 10:31 PM
idle current for bryston 4B Danielll Solid State 2 3rd October 2005 05:25 PM
class B and AB idle current demons_wing Solid State 6 6th October 2004 05:14 AM
XM-1502SX Idle Current sdoom Solid State 1 9th July 2004 07:35 AM
