Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 19th February 2004, 05:47 PM   #1
neutron7's Avatar
Default old ILP transformer
I found an old ILP transformer, and just need a bit of help to make sure my assumption is correct.
the transformer is made in canada and the part number is 5A027.
it has 2 separate secondaries which are wired in series for CT operation. it has a single primary.
the closest thing I can find now is on this page
http://www.amalgen.com.au/transformers/toroidal_5ur.asp
it says the 5 series are 160 VA, the dimensions are the same as the one i have. and the part number is the same except it is A0 instead of EU (america instead of europe?).
the output voltage is also correct.
so would i be safe to assume this is a 160VA part?
Old 19th February 2004, 06:14 PM   #2
5A027 is well a 160va (2x 20v at 4amp),input is 115vac.
Praudio
Using mains transformer as output transformer Elias Tubes / Valves 175 3rd November 2009 08:36 PM
Modulation transformer for a driver transformer? ironradio Tubes / Valves 6 28th December 2008 05:05 PM
filament transformer vs plate transformer contaxchen Tubes / Valves 10 14th January 2005 10:43 AM
toroid Transformer as power Transformer for tube tone Tubes / Valves 7 11th February 2003 08:57 AM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 04:36 AM
Page generated in 0.05606 seconds (78.54% PHP - 21.46% MySQL) with 10 queries
