Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
DIY speaker cables for Quad amp
Old 14th January 2016, 05:28 PM   #1
Cintronic is offline Cintronic  United Kingdom
Default DIY speaker cables for Quad amp
Hi
I have been reading a lot of different posts here about DIY audio cables and I have noticed specific designs only suitable for some amp / speaker combo's.
I am interested in making some for my set up but its not really high end and not sure it would be much benefit. My set up is Quad 405, Rotel pre amp RC-03 and some 90's B&W DM560.
Some of the cable designs I have read about are using braided cap 5 which seems quite economical but I am not sure my amp is suited to this. Other design I have seen that looks easer to make is Low-Inductance DIY Braided Hi-Fi Speaker Cables
Would either of these be suitable for my system or are there any other options to try?
Old 14th January 2016, 05:30 PM   #2
nigelwright7557 is online now nigelwright7557  United Kingdom
nigelwright7557's Avatar
I have always just used 13 amp mains cable.
I haven't had any problems with them.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 14th January 2016, 07:01 PM   #3
DF96 is offline DF96  England
It is highly likely that Quad gear will work well with any reasonable speaker cable, as it is not 'high-end' but merely competently designed. Mains cable will be fine.
Low inductance necessarily means high capacitance. High capacitance cables can lead to trouble.
Old 14th January 2016, 07:35 PM   #4
That cool. Thanks for replies. I will just stick to what I am using then.
I am just looking for and trying to eliminate weak links in my system and dying to try something DIY while I save for a nice speaker project.
Old 14th January 2016, 09:16 PM   #5
arnyk is offline arnyk  United States
Banned
Originally Posted by Cintronic View Post
Hi
There is a big controversy in the audio world as to whether those kinds of claims that are made for audio cables are fanciful or actual.
Generally, these claims are based on comparisons and auditions that are scientifically speaking, highly flawed.
Only a small minority of music lover audio systems actually contain special audio cables.
As a rule speaker cables need to be made out of cable that is heavy enough to deliver low distortion and flat frequency response across the speaker terminals. That depends on the impedance of the speakers and the length of the cable.
Unless your speaker cables are quite a bit longer than the typical 8 feet or less, or your speakers are highly atypical, ordinary 14 or 16 gauge lamp cord cable is technically sufficient.
Old 14th January 2016, 09:23 PM   #6
Cheers, guess I been geeking out too much. My cables are only 3 foot.
On subject of cables, they need to be equal for right and left speaker right. So if the amps nearer one speaker and theres more cable spare is it ok to coil the cable up to keep it tidy?
Old 15th January 2016, 07:08 AM   #7
eriksquires is offline eriksquires  United States
eriksquires's Avatar
Hi
One cool idea I read about was to unwind a copper-foil inductor. They are available in anywhere from 16 to 10 guage. Not sure what the cap and inductance was at the end of the day.
Not all low-inductance cable is also high-capacitance by the way. Just depends on construction methods.
Best,
Erik
All of my successes and failures can be explained by my attempts at getting a girlfriend. All of them.
Old 15th January 2016, 07:28 AM   #8
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
I've done that. One has to be careful with termination, i swap speakers all the time, and the foil cables kept breaking at the termination. Otherwise they worked well.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th January 2016, 09:00 AM   #9
Banned
Trying to match or minimize speaker cable length for cables a few feet long relates to visual aesthetics, not sound quality.
Old 15th January 2016, 09:02 AM   #10
Depends on the quality of the cable. Try this with 22 guage wiring. :-)
I would keep them the same length and try not to coil them very tightly or coherently. This will also mean less cable cutting when you move things around next.
Best,
Erik
DIY speaker cables for Quad ampHide this!Advertise here!
My new DIY speaker cables! Jim Leach Everything Else 8 25th November 2013 12:25 PM
DIY speaker cables paulspencer Everything Else 9 15th March 2011 07:36 PM
My 10lb DIY Speaker Cables cabsvrt Everything Else 2 23rd February 2011 05:49 PM
cables for diy amps, preamps, and speaker cables ... paulspencer Solid State 5 3rd August 2004 07:14 AM
DIY Audio speaker cables. 3beanlimit Everything Else 2 5th August 2001 06:55 AM
